Kyosho V-ONE RRR EVO 2
#2176
i was referring to the plastic brake pulley, not the 21t pulley.
i might give the 3racing titanium 2sp shoe holder a try.
anyone know how much lighter it weights compare to the stock one? i know the stock one is pretty solid/heavy
#2177
hi,
can anybody tell me what will change if I use the 23T pulley with standard belt (384)?
normally I drive 24T pulley with 384 belt.
#2178
i don't have any durability problems so far!it's a good buy i think!
(sry i answered in the wrong post)
#2179
You are going to change the overdrive ratio front to rear or visa versa. example if at 24 teeth you are getting 1 revolution at the rear wheel and 1 revolution at the front (for ??? number of engine turns) both front and rear are pulling evenly. But when you lower the teeth you are decreasing the revolution to those wheels and they are no long 1 to 1. In essence making the care a little more rear wheel drive or front wheel drive.
#2180
If you are referring to the plastic brake hub, it has an even shorter life...the brake disc would wrap around it...that is why Kyosho implemented an aluminum brake hub in the RRR WCTE kit.
#2181
ill see how long the brake pulley lasts.. then ill go back to the alumnium brake pulley.
the plastic brake hub weighs about 1g, while the aluminium one weighs about 4g. anyone know how much the evo2 brake/pulley weighs.
to bad you cant buy the plastic brake hub by itself... gotta buy the whole diff pack to get that part.
#2182
also has anyone tried adding weight to the front of the car/bumper to balance rear/front?
#2183
i dont know how you chewed through the plastic 21t pulley.. iv been using mine and has no sign of problems.
Also, this only started happening once I started using my JP eagle..not too sure whether there's a connection. So, basically, after every heat, the brake hub and 21T pulley were fried. Due to fear of not being able to purchase large quantities of these superseded parts, I started using an aluminum brake hub and pulley.
#2184
Seeking Rear belt and diff advice
Guys:
The rear end of my car seems to break free at exit of tight turns when I give it gas. I was wondering whether the rear diff fluid thickness has an effect on this?
I currently have light diff fluid in the rear (5,000 weight) mostly due to the fact that I didn't have anything thicker on hand. I'm toying around with the idea of replacing with thicker stuff, say 30,000 as per shimo. Would this have as effect to reduce the rear breaking loose or is this issue related to something else?
Also, any experience out there with rear belts snapping in half? I had one snap in half on me, fairly new belt (it was on it's third 30 min heat). Should I attribute this to fatigue and replace rear belts every second/third heat?
Appreciate any advice
thx
MH
thx
MH
#2186
#2187
stock spool - 25g
diff with titanium bevel shafts - 46g
is anyone running shimo clutchs? how do they compare to the older rrr clutchs? im deciding between shimo and capricorn
#2188
capricorn would be great except team epic (trinity) barely stocks parts for them. I have been trying to get shoes for 2 months in the usa, you may have better luck since they are closer to you.
#2189
its ok, basically all the 30mm clutches are good right now. you just have to find the right combination for the track. shoe, spring, gap then adjust the weights (on the pin or not, screws in the weights or not)
even the shimo clutch, there isent any parts availible for it yet (shoes etc)... only the full clutch set...
i wonder if capricorn shoes works on the shimo clutch.
#2190
i'd get the capricorn and 5 shoes, weights and a few springs all in one order. i have to eat the shipping from hong kong all the time.
