Trinity G4 - Team Magic G4 E-Type
#917
3racing do universals for the v one r in two different lengths, standard which i run in the front, but they bind if you run them in the rear, then they do a 2mm offset which i presume will fit alright
http://www.rcmart.com/catalog/produc...oducts_id=3391
#918
hey guys, i have a brand new g4 e class in the forsale forums if anyone is interested,thanks.
#919
#920
G4 EVO PRO Border kit
This our EVO PRO version we added instead the blue alloy plates to changes this too the carbon version.
and added some more goodies l see list below
- 4mm Lightweight chassis k1431
- With the new Fuel tank k1419
- Carbon side plates k1439
- K-factory G4 alloy rail mount k1432t
- Carbon brake bracket k1438
- Carbon arm stiffener brace k1442
- Super hard universal joint set k1462
- Alloy sliding steering servo saver k1470b
- Hard-coated alum. threaded shock absorbers
- Lightweight M0.8 2-speed system (super efficient)
- Vented brake disc & brake cam bearing
- Soft belts & lightweight dust-free pulleys
- Lightweight pivot balls
- Light weight middle & 2-speed shaft
- Full high quality ball-bearings
- Low CG front & rear gear differentials
- Specially designed 5th body post
- Carbon Radio Plate
- Front one-way set
- 30mm push type clutch set
- Front adjustable anti-roll bar set (with alum. mounts)
- Rear adjustable anti-roll bar set (with alum. mounts)
we can give you a special deal with motor and in-line pipe if you like we have all parts in stock from K-factory and TM
http://shop.the-border.nl/customer/p...634&cat=&page=
- Front one-way set
#923
Do anyone of you guys know where i can found a gear ratio chart for the G4? i've been searching around but i can't seem to find anything
#924
questions
brooklynrc - the steering servo is a tough pick because you do not have enough room to fit a standard servo in there. I am running a Futaba s9550. It is a good servo for the price if you can find them in stock anywhere.
JoeRocket- the best pipe for this car is the TM adjustable inline pipe. They sell for $60 in my store. The engine would vary on preference. I have a rossi black pixi in one of my g4s and a Sirio 12 evo 2 in the other. I like them both.
Has anyone run the solid rear axle yet. Does it make a big difference on the car?
#926
Your closest source would probably be rcnutshobbies.com or you can try The Border in the Netherlands. Scroll up, their link should be in this thread.
#927
broken parts
Originally posted by Scrad
Who should I contact for broken parts in my kit. Both of my droop screw holders broken after I installed the set screw and my rear upright did the same thing after I installed the ball stud. Should I contact team magic of trinity?
and if this not works we can help you out
#928
I bought it from my lhs that I work at. It seems like a manufacturing flaw. I got it on a scratch and dent deal. So I was wanting to get the parts replaced by team magic of trinity because it only has a manufacturs warranty. I was just wondering if anyone has has any problems.
Seperate note I must have the older tank, because there isn't a blue dot on the tank. I also had to use the o rings for the outdrives. My drivetran seems to be really tight one spot a little more than the rest of the revolution. I didn't soak the belts or anything, but I hope it loosens up after I break in the engine.
#930
Airtronics 94358Z steering servo
JR550 throttle and brake servo
