Kyosho VoneR Thread
#1336
Originally posted by Diva
Haven't I told you that the 5-star rear graphite shock tower plate provide an extra lower hole for the shocks? That's what I meant by "We like holes"
#1337
Originally posted by HEYALIGNMENTGUY
Looks like there are a lot of Kyosho parts out of stock in HK
#1339
Originally posted by Kenneth Tan
Hi,
Just got a V1R. Can I have some advice on how to build the diffs properly with out leaking? I am intending to use 30000 in front and 5000 in the rear. Thanks.
Hi,
#1341
But we are running touring car bodies and rubber tires... is it still possible to run oneways and solid axles? Thanks.
the diff is actually well made and you shouldnt havemuch problem when building it. just make sure you dont put excessive diff oil in it and it will not leak. besides, use 3mm machined screws instead of the stock 2.5mm self tapping screws as the stock screws will loose up sooner or later.
#1342
has Mr. Manticore taken Mr. Fok out to Lunch or Dinner wile Mr Fok is on his vacation
#1343
#1344
Originally posted by Manticore
you may still run with a front one-way with rubber tire.
#1345
Forget the diffs. Get the oneways and solid axle with VDS shell. That's the way we built the cars.
#1346
No, Mr. Fok doesnt want to show up with his bad legs !
Wha what? Where am I suppose to show to? Is Manticore giving me his cars? If so I'll walk anywhere.
#1347
Originally posted by adelmundo
DANGIT Thats's the death of Touring Cars! Pretty soon all the cars will look like 1/8th scale cars! If you want a car with front one ways and solid rear, foam tires, and the Lola (1970's body which you don't even really see now-a-days in real 1:1 car racing) then get a 1/8th scale or even a 1/10th 235mm (ie Serpent Impact). TOURING CAR IS TOURING CAR! That's why it was created! To have cars that sort of actually look like mass production cars. Oh well...I'm just ranting (I also own a V-ONE R with front one way and solid rear, Lola VDS body, and foam tires hehehehe )
#1348
#1349
W Fok will hobble anywhere for quality RC stuff
#1350
But are we having fun with what ya got last time I saw you you just turned your fastest laps at Delta with your touring car I did see that smile on your face
