Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 07-21-2002, 07:44 PM
  #3121
Jack's Avatar
Originally posted by lonestar1127
hi can i know what size of the rear foam tyres u guys use???
26mm or 30mm
hey lone... some people use 26 some use 30......
If u want to find out more.. drop by the track and look around
Jack is offline
Old 07-21-2002, 09:46 PM
  #3122
Originally posted by Glenn
Does the kawa engine mounts on the counter sunk washers for the screws like the kfactory ones?
There are no countersunk washers for the Kawahara mounts
HEYALIGNMENTGUY is offline
Old 07-22-2002, 06:45 AM
  #3123
Manticore's Avatar
Originally posted by boner
yup you need a different chassis to take the 4mm mount.
3 racing V1RR main chassis has 4mm engine mounting holes but the chassis has light accuracy issue. the long belt is tight with it.
Manticore is offline
Old 07-22-2002, 06:53 AM
  #3124
Originally posted by VenomWorldOrder
i thought you were being sarcastic....
anyway just put it in via the glow P hole put the plug back in and spin it on the starter box. don't worry about putting too much the extra oil will go to the engine bearing and protect that. any excess usually comes out via the bearing.
i use a oil which is available in k mart called 3 in one.
I didn't mean to come across as sarcastic, I just wanted to know how you guys use after run because I read so many different opinions on it.
Thanks for the replies!
BeaV1s is offline
Old 07-23-2002, 01:35 PM
  #3125
Regional Moderator
racer rich's Avatar
V-One RR Rear Hex Adaptors
I have a question on the Rear Hex Adaptors that come with the V-One RR.
I know that the Rear Dogbones are shorter than the Front Dogbones to keep the V-One RR at the 200mm limit, but in the rear does the V-One RR use the Rear Hex Adaptors that are narrow in size (normal, with NO offset)? Or are they WIDE Hex Adaptors (with Offset)? To use 30mm Rear Foams with the V-One R you have to use the aftermarket WIDE Hex Adpators so the tire itself won't rub against the rear hub carrier, but since the V-One RR has shorter rear dogbones and a different rear-end design I am not sure if it still uses or needs the WIDE Hex Hubs in the rear-end of the car. I race on a ROAR track so it has to be kept to a 200mm maximum.
I am thinking about upgrading to Aluminum Hex Adaptors for the V-One RR. I just want to make sure to get the right size Aluminum Hex Adaptors for both front and rear before I buy them.
Thanks in advance!
racer rich is offline
Old 07-23-2002, 01:44 PM
  #3126
VONEREFLEXR's Avatar
Hmmmm, Not sure if anyone has touched on this subject but 98.9% of the parts on the Trinity Reflex work on the V-One R. Isn't that a little weird
VONEREFLEXR is offline
Old 07-23-2002, 03:05 PM
  #3127
AMGRacer's Avatar
Default Re: V-One RR Rear Hex Adaptors
Thanks in advance!
It uses the normal hex adaptors. A 2mm spacer is inserted between them and the bearing to space it out.
AMGRacer is offline
Old 07-23-2002, 09:14 PM
  #3128
Hey Manti..........any word on those Ts
Old 07-23-2002, 09:19 PM
  #3129
Manticore's Avatar
Oh, the TiCore will be available next week !!
Old 07-23-2002, 09:28 PM
  #3130
Oh OK Your the one in Charge
Old 07-23-2002, 10:16 PM
  #3131
Has anyone here ever tried the 24t rear pulley conversion?
CRAZY top speeds, better mileage, longer engine life, smooth rolling resistance.
Some dudes at my shop beat me to it, but from what I've felt when pushing their cars across the floor, its VERY smooth (from the conversion alone).
All sounds good to me, mine will be done soon....
rbgti is offline
Old 07-23-2002, 10:35 PM
  #3132
VenomWorldOrder's Avatar
are you talking about the pulley that connects the rear diff to the 2 speed shaft or the rear side pulley?
VenomWorldOrder is offline
Old 07-23-2002, 10:53 PM
  #3133
The pulleys on the 2-speed shaft, yes. There are 2 of them.
One goes to the rear diff, the other goes to the front mid pulley.
CRAZY CRAZY CRAZY!!!!!!
Can't wait.
Oooh by the way it is even better if you lighten the shafts with titanium ones. Which are on the way as well
rbgti is offline
Old 07-23-2002, 10:54 PM
  #3134
Both stock ones are 19t. The mod uses 24t aluminum ones.
rbgti is offline
Old 07-23-2002, 11:12 PM
  #3135
so the mod is changing the 2 pulleysto 24T? what happens if i have the RR side pulley mod already done? will it work? won't this mod give too much drive to the rear?
