Kyosho Gas powered 1/12th pan car
#1006
Snow is gone and Mika is running...
Cool video. Well prepped car.
Now find another and go race!!
#1007
Indeed! Thank you Sir!
Next.. I'll go to the track once have the chance and race with .. whomever there is
#1008
I know i asked this question a couple of years back but, how does the s09r , compare to the stock motor? Is it worth the price? If so, does someone else carry it other than the-border? Tx.
#1009
http://www.amrtech.com.tw/products/pd_list.php?sid=2
#1010
RPM seems higher and I can feel a more speed when fitted with 2speed. It seems to need more maintenance! I am also looking into the AMR Scud 09r engine.
If you get that AMR let me know how it compares!
#1011
Looks like a composite pipe, can you confirm? It's a good feeling to see Kyosho coming out with new vehicles in a brand new classes
#1013
Let me know if it fits and how it goes!
#1014
Hi, seeing you question regarding the "R" motor just now - I only have the head, the motor itself is the same stock engine, although nowdays I have OS 4-stroke on it. Video http://www.youtube.com/watch?v=WzwWLmrdoFE and http://www.youtube.com/watch?v=lp9h2p1vti4
#1015
EGR Mart
#1016
#1017
The amr is a direct fit in the Spada. No mod needed to make it fit. AMR does sell a conversion for the spada but its just basically their .09 motor with a flywheel and motor mount and same HP as the kyosho stock but with higher rpm. The .12 I went for is the same size as the stock but has .12 cc specs and 1.3 hp. Only different is higher profile due to larger heat sink. You will need to buy the spada specific flywheel and motor mount it comes with nut and screws with flywheel.
EGR Mart
EGR Mart
#1018
Here's a few
I would like to try the front spool instead of oneway (I think the 09L has it by stock) and also a better pipe solution.
The only tool I have is a dremel so my shop is a bit limited what comes to building. I made the carbon chassis myself to extend it a bit. I think the 09L chassis would be fine, too. I have 3mm carbon waiting to fine tune the chassis.
#1019
Still in break in mode! I had the 09 plus but sold it for the .12. Its still available but EGR is alway sold out. I guess cause price is so good? Shoot them an email they are very helpful to me. The Plus had 1.02HP and slghtly lower CC1.6 The .12 has 1.96cc. I actually threw away the stock motor when I ran the Plus! It was so fast from low to top end and actually made the car handle better cause of the extra weight. The .12 started up right away and is loud for its size so I am expecting something special! Ceramic diff balls is a must and expect to refuel more often. I'll never go back to stock!
#1020
Many thanks.
Here's a few
Here's a few
