Mugen MTX-4R
#1517
I use mugen 50000 with a lock front diff. pretty much at all the tracks I raced on. It also depends how technical and small the track is. 30K would be a good starting point. At the Rams 40th anniversary race, I used 100K just because the track was so huge. I know that some of the other mugen team drivers used 50K in thier R's for that race.
#1519
Softest to Hardest :
Red -- Yellow -- Black -- Grey
Check your centax spring, clutch gap, and endplay.
#1520
Advise?
Hey guys i striped 2nd gear the other weekend...
and am have trouble getting the round clip pin off, any advise on how to get this off ?
this is the first gear ive stripped and was because i gave the gf a go and she crash headon into a wall, must of moved the motor a little, best way around this; move the motor back and cover the screws in locknut??
thanks in advance
thanks in advance
#1521
and am have trouble getting of the round clip pin, any advised on how to get this off ?
thanks in advance
Attachment 336718
thanks in advance
Attachment 336718
#1523
when I set my ride height, the rear spring shocks have 1mm play up and down on the shock when i lift the rear. When I tighten the shock to have no play of the springs the ride height is about 10mm.
How can I get rid of the play and get the ride height I want?
Having the spring loose one the shock, doesnt affect car performance?
off power the car will not transfer all the weight is supposed to the front and loose turn in?
#1524
#1528
hope this helps
#1530
Coat Hanger
If I was in a situation where I had no other choice I suppose I would also use anything that came to hand. But can you honestly tell me you do not mind having a part made out of a coat hanger on your multi hundred $$$ machine???? For me an MTX4-R (and any other one of these specialised circuit RC cars) is a Precision Tool ...there's simply no room for coat hangers and the like but hey ...whatever floats your boat ...
