Xray NT1
#92
Originally Posted by rmdhawaii
#93
Originally Posted by itchy b
If you did get it you'd need to hire some drivers and build your own team
When are we going to see some actual pictures of the chassis?
This cloak and dagger stuff is getting a little long in the tooth
It's had its maiden Race meet win!
They should make with the photos already!!
#95
The build of the car was fantastic, the multi engine mount gimmick is trick, its on par with everything out there that's competitive, period. They started out with the "kit stock" set up and went from there. Nice ride and just like everything else driven by a skilled profesional its a WINNER.
Cant wait for the touring a at the winter nats.
#97
Originally Posted by Diesel Racer
Did the car look to have any significant advantage on the track compared with the Mugens, Serpents and Kyosho's or was it down to Barry on the sticks?
Diesel Racer
Diesel Racer
Check the results of the 1/10 A main and you will see that the lap times were good and he was very consistant. If they want to truely know how good the car is he should have switched cars with me and see how I finished. That would be the real test for the car and not the driver.
http://www.forgass.com/
#98
Pinions and spurs are diameter compensated, the engine mounts are "cut in half" horizontaly. The brand of engine has its own specific upper mounts that the engine bolts to and the lower part of the mount bolts in the car.
#100
Thanks for the info guys, any other snippets you can share; i.e: was it running a 3 or 4mm chassis and from the original images it looks like a sealed receiver box and the standard XRay plastic shock bodies?
Cheers, Diesel Racer
#101
#102
The pullies on the car also were nice and thick. Not like the mugen ones, when the pipe gets hit, it ruins the pully, they had a nice and thick shield on the pully, as to prolong belt life and keep them from warping. Nice trick with that. This car is built to be tough and keep you on the track.
#104
always wondered why wouldn't do the universal engine mounto similar to
the buggys where taking out the engine and putting it back needs no readjustments on the gear mesh.
nice to see a new addition in the nitro scene, and of course the winternats should be a very mix up of the best of the best on both classes
happy racing!
happy racing!
#105
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
happy racing!
happy racing!
18Likes
