Like Tree18Likes
Xray NT1
Old 03-01-2008, 08:08 PM
  #2776
Default Serpent parts
Can I use the Serpent Centax III yellow shoe with the NT clutch? The yellow shoe isn't in stock locally and I was wondering if the Centax III shoe would do.
going4#1 is offline
Old 03-01-2008, 08:40 PM
  #2777
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
no their different in size.
Serpent-Dan is offline
Old 03-03-2008, 08:36 AM
  #2778
RC MARKET's Avatar
new parts arrived
RC MARKET is offline
Old 03-04-2008, 09:20 AM
  #2779
Default Kissimmee
Hi,
Can someone post a good starting point for a chasis set up for the Kissimmee track?
Thanks in advance,
Joe
Joe Chaplow is offline
Old 03-04-2008, 09:33 AM
  #2780
The X-Ray forum Paul LeMieux has a set up for Kiss.
Old 03-04-2008, 01:43 PM
  #2781
teamgp's Avatar
Originally Posted by Joe Chaplow
Hi,
Thanks in advance,
Joe
For Kissimmee, I would actually recommend starting off with Ralph Burch's US Winternats '08 - Winning Set-up.
I ran the setup this past weekend at 301 Raceway, with relatively low grip, and the car was the best it ever has been there for me. It was only 90% dialed at first, but still fast and easy to drive. A few tweaks later...
This is a really good base setup.
teamgp is offline
Old 03-04-2008, 01:53 PM
  #2782
Joel J's Avatar
Trader Rating: 23 (100%+)
Will you happen to know the setup here at Crystal Park CA. Thanks...
Joel J is offline
Old 03-04-2008, 02:27 PM
  #2783
teamgp's Avatar
I really don't know, and I couldn't find one on the XRAY site.
As I said before, Ralph's setup is a good base setup, or you could start with the basic setup.
teamgp is offline
Old 03-04-2008, 05:27 PM
  #2784
thanks for your advice. do you know if he was running a spool, oneway or a differential upfront?
Old 03-04-2008, 05:41 PM
  #2785
The stock set-up is better to start off with then start tweaking it to your driving style. And Ralph ran a spool at Ft. Meyers.
Old 03-04-2008, 06:12 PM
  #2786
thanks
Old 03-04-2008, 06:55 PM
  #2787
teamgp's Avatar
He ran a spool up front and a rear diff with 30k (filled full; more than the manual states).
teamgp is offline
Old 03-04-2008, 07:22 PM
  #2788
teamgp's Avatar
I have to disagree with you on this one. If you take a look at all of his and Barry's setups throughout the year, you'll find that there are some key changes that they made and kept for a good base setup for the next race.
I believe his recent Winternats setup is more of an evolution of the basic setup. Keep in mind that the basic setup was developed over a year ago in more controlled conditions and on European tracks. As with anything, time and experience changes things.
While at the Winternats, I decided to use his setup and only had to make a few tweaks to tailor it to my driving style, which is much different. The immediate difference for me was 0.5s/lap on changing the setup alone, before I made my tweaks. If you play around with caster, front toe-out, anti-roll bars and of course tire shores, you should be able to dial it in to your own driving style. Rear toe-in and diff fluid wt should be changed to suit the track grip conditions.
However, the rest of the setup (shock position, spring, oil, pistons, roll centers, camber links positions, down-stops, track width, ride height, etc.) is the best balance I've seen or felt on the NT1, both at Ft Myers and at our totally different local track (301 Raceway, which is more like the large flowing European tracks).
teamgp is offline
Old 03-04-2008, 07:29 PM
  #2789
What I'm saying is for someone starting out with the car for the first time go with the stock set-up and then make changes to your liking or try a posted set-up. Not everyone can get the same out of a set-up the way Ralph or Barry or Paul you need the base starting point then take it from there.
Old 03-04-2008, 07:43 PM
  #2790
teamgp's Avatar
I agree with part of your point. However, a base starting point doesn't stay static. As the team drivers learn the car over the course of a years racing, I'm pretty sure the base setup, which brings overall balance, evolves.
If I can use Ralph's setup as is and instantly improve my lap times, then I stand to believe that most, if not all, can.
Here's a saying I use to keep reminding myself of some things...
'Thats why they get paid the big bucks.'
They know what they're doin...
teamgp is offline
