Kyosho V-ONE RRR Evo
#1832
http://www.rctech.net/forum/showthre...25#post2977625
#1833
whats tool do you use for rear turnbuckle? i measured 5.5mm but i can't find a tool with this measure
#1834
thanks RMD
RMD, thanks for that link. Boy, they really don't make that info easy in the kit literature.
Are there other springs that work with the Evo shocks (that people use and recommend)? I guess I rely on springs a lot for tuning, and three seems like a pretty small tuning range. Maybe I'm wrong...
#1835
Ok, i have this problem that the back end keeps breaking out when turning on power or in quick left right corners. I had it with my wce from last year and also with my evo this year. I tried a lot of things like change the camber, caster, tires, camber links, springs, diffs, clutch, body and wings. And i don't really know what to trie next. On tight technical tracks it is worse than on large flowing tracks. At the end of last Sundays race i basically got back to the evo stock setup with the exception of 2 droop up front and the front anti roll bar in vertical position and a front diff (100k). This was on a tight technical track.
Does anyone has an idea what the problem could be?
#1836
sounds like something is binding, or your breaks arn`t set correctly, could be your diffs, could be many things
#1838
#1839
I usually use the droop settings to get more on power steering, so usually i have more droop at the front than the rear. Could that be the problem?
#1840
I completely rebuild my car between each race weekend, everything was moving nice and smooth, brakes are set verry low as i dont really brake much. Diffs were checked and i also have a couple of build diffs ready so i can change them fast between heats.
#1841
on the front i have 2 droop and the rear 4. Only changed the front to get more steering.
#1843
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
#1844
RRR Hardened Outdrives
Hi Guys,
Have any of you seen or used these option parts yet - I am after some harder outdrives for my V-One RRR (as the stock items are crap). I have a freind who recons he has had one of their radio trays and likes it but I wondered if any of you had seen these:
http://www.benracing.co.uk/acatalog/...ion_Parts.html
#1845
Hi Guys,
Question for everyone... Without flipping the outdrives to use the other side, how long are the outdrives lasting on your cars? Since it's difficult to measure this by distance or even time, I'm gauging it by the amount of fuel used.
In my situation, I just finished a gallon of fuel on a new V-One-RRR Evo WCE chassis and the outdrives are so worn that it was causing handling issues. What was occurring was the CVDs would stick in the worn out section and bind up the suspension. This caused a "chatter" or "hopping" effect on acceleration and induced a push to the car in high-speed turns.
