Team Durango DNX8 1/8th Nitro Buggy >
    Hide Wikipost
Old 11-11-2016, 07:23 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Durango DNX8 1/8th Nitro Buggy
Last edit by: tobamiester
Finally , its launched : [URL=http://www.team-durango.com/race-cars/dnx8/[/URL]
Part# TD102040.
As more information becomes available, i'll update the first 2 posts of this thread. Please PM me if you find more info you'd like to put on here. Cheers
Link to manual.
Link to setup sheet.
Blog from Travis 3/27/2015 http://www.team-durango.com/blog/tag/travis-amezcua/
Build info : [url=http://www.tdbuild.info[/url]
Get Support: [url=http://www.tdsupport.info[/url]
FEATURES
*Chassis: Hard anodized 7075 T6 aluminum, 0.12" (3mm) thick
*Drive: Four wheel
*Shocks: 16mm Big Bore aluminum body with vented caps, and a choice of
constant volume and emulsion bodies
*Shock Towers: 0.20" (5mm) thick milled aluminum
*Suspension: Fully adjustable pivot ball with square hinge pin inserts
for more options for front end mods, galvanized components for
protection against oxygenation
*Differentials: Ultra lightweight bevel gear type with composite cross
shafts for increased acceleration and durability
*Fuel Tank: --oz (--cc)
*Clutch Bell: 13T steel
*Steering:
with adjustable Ackermann, Ackermann refers to the effect of the
the inner front wheel rotating faster than the outer front wheel
during turns
*Rear Body Mount: Floating type for increased body life
*Battery Box: Fully enclosed for maximum protection
*Body: Pretrimmed polycarbonate with cab-forward design
*Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis, Active Caster Inserts for quick changes
*Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Vehicle;
*Length: 20.9" (522mm)
*Width: 12.1" (307mm)
*Height: 7.3" (186mm)
*Wheelbase: 12.7-12.9" (322 - 328mm)
*Racing Weight: 7lbs 8oz (3.4kg)
Essentials
a) IMPORTANT: Use wash like MUGE0161 "Mugen FRONT TRACK WIDTH ADJUSTMENT SPACER) on lower Pivot balls to prevent premature failure.
Dimensions of washer: 6mm inner and 14mm outer so any equivalent brand will work.
Recommendations
a) Use Alum Servo Arm
TD340122 25T
TD340123 24T
TD340124 23T
or Hot Bodies 67168 24T, 67169 25T or 67167 23T
b) The tank lid seal can be adjusted with the screw in the centre. The tighter the screw the LESS the tank will seal. Screw-off 1 or 2 turns just make it perfect.
c) For the front bumper not touch the inserts, also have removed the boss inside the front bumper
The front bumper on the buggy has two standoffs on it, each standoff is positioned right over the insert on either side, if you nose dive to hard or hit the front awkward the standoffs can push your hinge pin through the back insert.
The fix is to dremel off the standoffs.
d) Also, glue the nut in the servo-saver
e) Shock Build options
For Emulsion build see this post:
[url=http://www.rctech.net/forum/14014032-post310.html[/url]
Bladders are TD330589
After Market Upgrade
RPM Wing Mount [url=http://www.rpmrcproducts.com/shop/chassis-components/chassis-accessories/arrma-durango-wing-mounts/[/url]
Print Wikipost
Old 10-19-2017, 05:24 PM
  #841
wfo
wfo's Avatar
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
How well do the aluminum clutch shoes wear? are they 7075?
wfo is offline
Old 01-25-2018, 11:52 PM
  #842
Anyone still running DNX8 or planning to run it during 2018 season?
I am planning to run the car still during 2018 season, had pretty decent season with DEX8 in 2017. The car suits my driving style very well and with certain tweaks/mods the car is pretty durable.
micsa is offline
Old 04-05-2020, 10:23 AM
  #843
Anyone have any spare 110mm center driveshafts?
Ondaedg is offline
