Team Durango DNX8 1/8th Nitro Buggy
#693
Finishing up on my DNX8 here shortly.
Ran into a couple weird things I'm not comfortable with.
The big one is this little arm/connector thing that goes from the top gear of the servo, through the same screw as the servo arm, and to the rear right side screw on the ctr diff.
Did any of guys actually do that?
I'm really thinking I don't want to and I wonder what other way is there to strengthen up that servo mounting.
#694
#695
You can run it without the brace if you want to as the tray is pretty stiff but I recommend using it as it will help with the consistency. The ball will pivot with the servo arm, I never had a problem with it. Just put a dab of blue loctite on the screw so it doesn't come out and make sure it's not too tight so it won't bind. I love my S350 EVO II but I kinda am a fan of my old DNX8's radio tray. Just seems simpler and more direct.
#696
There's some things I like and don't like about the radio tray set up on this. One thing I don't care for is the size of the rx box. I have 3 other projects going on right now too: 1st gen XB8, OFNA 9.5 Pro, and RC8.2e that I'm converting to nitro. All3 of those have huge rx boxes and I love it. I like having more space than not enough.
#697
So with Loctite on the screw, does it then get tightened at all? So that the little ball in the connector is doing the turning inside the plastic part?
#698
Tech Legend
the radio box screws (assuming they are the same on the dex8 and desc10 which I have) I use AE's black hex driver on from what I recall, I forget the size but its definitely not a 1.5mm screw head. They fit very snug in the screw, no stripping.
Personally I would have rather had something that had a simple 1 screw latch flipup box.
#699
Here are a solid solution with the possibility of more precise setting.
(Triangle / carding of RC8B 93.5mm )
https://www.facebook.com/photo.php?f...type=3&theater
#700
What issue is the picture above meant to be addressing?
#701
#703
Hello
I just deleted some defects dnx8 .
I chose to mount the triangles / rocket / carding 93.5mm front RC8B3 ( more could pull a steering ball) .
The diff dnx8 games take too quickly at the nuts , so I replaced the boards with diff tki3 / 4 with the brake discs since dnx8 brake discs are badly calibrated.
All amounts without any change you just 3 shims for diff cells in forward / back .
Now my DNX8 is perfect and very reliable.
Bonjour
J’ai juste supprimé quelque défauts du dnx8 .
J’ai choisi de monter les triangles/fusée/cardant 93.5mm avant du RC8B3 (plus de risque d’arracher une boule de direction).
Les diff du dnx8 prennent trop de jeux rapidement au niveau des noix, alors je les ais remplacé avec des diff de tki3/4 avec les disques de frein puisque les disques de frein du dnx8 sont très mal calibré.
Tout se monte sans aucune modification il faut juste 3 rondelles de calage pour les diff dans les cellules avant/arrière .
Maintenant mon DNX8 est parfait et très fiable.
for more picture here is my facebook page https://www.facebook.com/guy.montange
Bonjour
#704
Lol just woke up from night shift thought I was crazy trying to read that last post then realized its not translated lol
#705
Tech Legend
Hey guys, Bigbearfins buddy who makes his graphite parts has offered items for sale. More pics to follow but here is the list:
Code:
Product# Product PRICE (Euros) 500300 DNX8 Front Shock Tower 5mm CF 25,00 € 500310 DNX8 Rear Shock Tower 4mm CF 27,02 € 500400 DNX8 CF Servo Plate Kit 2mm CF 11,69 € 500410 DNX8 KoPropo Switch Plate For Servo Plate Kit 2mm CF 6,05 € 500420 DNX8 Switch Plate For Servo Plate Kit 2mm CF 6,05 € 500430 DNX8 Center Diff Top Plate 2mm CF 6,05 € 500440 DNX8 Steering Knuckle Plate 3mm CF 6,05 € 500200 DESC10 '15 Front Shock Tower 5 mm CF 25,00 € 500210 DESC10 '15 Rear Shock Tower 5 mm CF 27,02 € 500220 DESC10/DNX8/DEX8 '15 Steering top plate 3mm CF 17,34 € 500230 DESC10 '15 Chassis plate 3mm CF 114,52 € 500240 DESC10 '15 Chassis nose 6mm 7075 Aluminium 25,40 € 500250 DESC10 '15 Front top deck CF 3mm 15,00 € 500260 DESC10 '15 Rear top deck CF 3mm 15,00 € 500270 DESC10 '15 Battery fork CF 3mm 2pcs 6,85 € 500280 DESC10/DNX8/DEX8 '15 Ackermann plate 3mm CF 11,69 € 500290 DESC10'15 Hybrid Carbon Fiber Chassis KIT 3mm 160,48 €
