Tekno NT48 Thread >
Tekno NT48 Thread
Like Tree13Likes
Tekno NT48 Thread
Old 01-12-2018 | 08:25 AM
  #1636
I would say clutch bearings/chassis bearings, extra tank, hinge pins/hinge pin inserts, shock shafts...arms/spindles/c-hubs/rear hubs if you feel like spending more, though I can't remember the last time I saw a Tekno truggy outright break.
Oh...and if you're running the stock clutch shoes...extra shoes, they wear pretty quick with the stock setup. We switched to a 2-aluminum and 2-carbon shoe clutch setup (using Serpent carbon shoes 600228) and the shoes are lasting at least 2 to 3 times longer now.
shearpin is offline
Old 01-25-2018 | 08:48 AM
  #1637
Cain's Avatar
Tech Legend
what would you guys say are the main items to get if going from an NT48 vehicle NT48.3 specs?
For example, hingepin carriers versus some other items which is more bling.
Thanks!
Cain is offline
Old 01-27-2018 | 07:03 AM
  #1638
Cain, to be honest, the biggest changes from the original NT48 to the .3 are the chassis, fuel tank and spur. There was an issue with the original NT where on a hard landing the chassis would flex and it could take out the spur gear. Be sure to use the latest spur from the NB48.4.
Cain likes this.
MattDub is offline
Old 02-01-2018 | 01:05 AM
  #1639
the updated throttle linkages are nice also
TrespasseR_MN is offline
Old 02-01-2018 | 07:06 AM
  #1640
Cain's Avatar
Tech Legend
perfect thanks. will keep an eye out for an NT48.3 edition then,
Cain is offline
Old 02-16-2018 | 09:25 AM
  #1641
Cain's Avatar
Tech Legend
alright got a NT48.3 in here. Looking at Tekno's site it appears there are 2 starting setups or ones to use as starting setups? I will run on loose conditions, is there one you fellas feel are better to start with?
Cain is offline
Old 04-06-2018 | 11:11 AM
  #1642
Cain's Avatar
Tech Legend
anyone?
Cain is offline
Old 04-06-2018 | 11:31 AM
  #1643
anyone?
I didn't answer, as personally, I didn't like any of the setups I found for our loose dirt bumpy track.
I would personally start with my setup I have attached. Let me know your thoughts.
File Type: pdf
ezlight is offline
Old 04-06-2018 | 12:21 PM
  #1644
Cain's Avatar
Tech Legend
thanks, will take a look and compare to the nitro specific ones.
Cain is offline
Old 04-10-2018 | 12:36 PM
  #1645
portyansky's Avatar
this one will get you really close to where you want it
Cain likes this.
portyansky is offline
Old 05-11-2018 | 09:03 AM
  #1646
what is a quick way to determine if a kit is a .1 vs a .3- have a line on a great deal but don't know how to tell quickly which one it is
rjkotzur is offline
Old 07-11-2018 | 12:11 AM
  #1647
ericmyson's Avatar
What is the outright best starter box to use on this NT48.3 TRUGGY?
THANKS IN ADVANCE
ericmyson is offline
Old 07-11-2018 | 07:17 AM
  #1648
The general consensus is...
The blue Ofna truggy box
shearpin is offline
Old 07-11-2018 | 09:27 AM
  #1649
Reno's Avatar
What he said.
Reno is offline
Old 07-15-2018 | 08:32 PM
  #1650
Part from m2c thorttle l sharp horn what other thorttle servo horns out for this car
MadMick is offline
