Tekno NT48 Thread >
Tekno NT48 Thread
Like Tree13Likes
Tekno NT48 Thread
Old 07-21-2016 | 09:41 AM
  #1546
HaulinBass's Avatar
Originally Posted by bypass911
Cool thanks for that info! I gotta try one myself. I'm barely getting 7 minutes on the roma with a 7mm restrictor and I want at least a minute more.
im not running a tekno but on my local track im getting about 8:30 with a restrictor bored to 9mm 9901 pipe 41005 header in my d8t running full wood allot of the time.tried to push 10 minutes once when i forgot to pit but ran out of fuel with 20 seconds left
mine is a nitroshop mod with a ceramic rear bearing(mine was the dyno charts neal posted).the paloma has to be the fastest motor per $ out there.
HaulinBass is offline
Old 07-21-2016 | 09:59 AM
  #1547
bypass911's Avatar
Cool, thanks for the info.
bypass911 is offline
Old 07-22-2016 | 11:21 PM
  #1548
bypass911's Avatar
Just figured out why i was chipping spur with the m2c mount. The .25 roma has a slightly bigger crank case than .21 size motor. The mounting holes are slightly further away and because the stock mount uses seperate left and right mount, it doesnt cause any issue but the m2c mount, mounts to one piece main body. This caused an improper fitment and the crank case to tilt at some point. The reason why the m2c was fine on my buggy was because I was using Nova keep off 4 .21 !
So just a heads up guys dont mate the m2c with anything bigger than a .21
Old 08-08-2016 | 12:05 PM
  #1549
samuelsonmark71's Avatar
NT48.3 is on order. I know on the NB48.3 page there is a wiki on key things to pay attention to and things to get for the car (part wise). Is there a list of things to pay attention to or things that are needed ASAP for the truck (other than what is mentioned in the first post)?
Thank you
samuelsonmark71 is offline
Old 08-09-2016 | 03:45 AM
  #1550
B3nno810's Avatar
Thank you
Tekno aluminium servo horn, Tekno Delron shock guides, M2C delron shock bushes, M2C aluminium throttle servo horn and you should be set.
B3nno810 is offline
Old 08-09-2016 | 05:47 AM
  #1551
so the same things I have on the Buggy, got it. thanks!
Old 08-18-2016 | 07:07 PM
  #1552
bypass911's Avatar
Anyone know if I can fit kyosho St rr universals on our trucks?
Old 08-19-2016 | 10:23 PM
  #1553
troyniesentrams's Avatar
Looking for tekno nt48 or nt48.3
troyniesentrams is offline
Old 08-22-2016 | 03:56 AM
  #1554
R/C Tech Elite Member
Bypass911,
I can tell you they will not work, because I tried. They are about 10mm too short.
Now that Tekno has universals available for the EB48/NB48 platform, hopefully they will release some for the ET48/NT48 platform.
moto775 is offline
Old 08-22-2016 | 04:52 AM
  #1555
Maximo's Avatar
Originally Posted by bigbenmbx7t
I thought it was shimmed to far out as well, I took the only shin that was before the rear bell bearing out and it still didn't touch the far rear portion of the shoe, Maybe I'll try another rear bell bearing and see if it fits better. All the Losi clutched I've seen create that same ledge on the far rear portion of the shoe. But thanks for the input. I dremel'd the bell with a wire brush, I'll see if it wears into the werks shoes the same way on Friday. If I have time I'll swap back to the TEKNO clutch between qualifiers and see how it acts with the bell being worn in better.
did you breakin the clutch ? this is very important and if not done correctly you can see extremely rapid clutch wear like you have seen......
Maximo is offline
Old 08-22-2016 | 04:55 AM
  #1556
Maximo's Avatar
my modified Roma would give you nearly 10 (if not 10 ) pretty easily ! using a much bigger insert no less.............. A huge issue is setup, pipe and manifold...small inserts don't always pay off with increasing mileage and in some cases can make it worse...for a .25 a 7 mm is too small and is choking the engine and making it work harder....
Maximo is offline
Old 08-22-2016 | 09:05 AM
  #1557
bypass911's Avatar
Originally Posted by moto775
Bypass911,
Cool thanks for that info, exactly what I wanted to know.
Since the StRR unis are 130mm we need to find something around 140mm.
Old 08-22-2016 | 09:21 AM
  #1558
bypass911's Avatar
Even stock Roma was too much power for me even with a 7mm. With a 9mm insert and 9886/41001, it was absolutely insane. I think it'll either hang or beat my os .28xz . Roma was also putting more stress on my drivetrain especially clutch bearing. With the Roma I learned you need to use metal shield clutch bearing otherwise the torque and speed melts the rubber shield. With the 9mm on the Roma it took out TKO clutch bearing after 4 tanks. Now I slapped in a .21 and will be running the Roma on my GT.
Old 08-24-2016 | 12:45 AM
  #1559
bigbenmbx7t's Avatar
Yes I broke it in just as I would any other clutch. I put brand new shoes in, a brand new bell and broke in the clutch. Tried using it again and it still wears much faster than the lutz or werks clutches I run. I'm just sticking with the lutz clutch now. It has held up after long mains and wears nice. Helps they are much more affordable as well. I've found for me coming from Mugen I have to set the truck up very soft AE oils 35 in the front and 30 in the back with taper up. It drives like a dream now. I had my p7r Evo 3 barely broken in last weekend and the top end needle housing backed out in my main. Kinda wrecked my weekend and my points for the series but it is what it is.
bigbenmbx7t is offline
Old 08-28-2016 | 05:00 AM
  #1560
Club race at thunder road hobbies https://youtu.be/pdGaX47btrA
Kyosho 777WCJC is offline
