Tekno NT48 Thread >
Tekno NT48 Thread
Like Tree13Likes
Tekno NT48 Thread
Old 07-11-2016 | 08:35 AM
  #1531
jjhall's Avatar
Originally Posted by jjhall
Tower has the NT48 kit for $325 before Super Saver Club coupons and e-cash promo..
....and its sold out
jjhall is offline
Old 07-17-2016 | 01:02 PM
  #1532
bypass911's Avatar
I should let mitch know about this but the m2c engine mount has problems. Kept breaking my hardened 46t spur teeth. Went through 3 spur no matter how I mesh. Put back the stock mount and no more problems. It seems fine on my NB48.3 but definitely not working on the NT48.3 for some reason.
bypass911 is offline
Old 07-18-2016 | 10:28 AM
  #1533
What rear brace set up are you using? I still run both braces in the rear on mine and never had an issue with spurs breaking...tho I'm running the 48t
Neesh is offline
Old 07-18-2016 | 10:38 AM
  #1534
bypass911's Avatar
Are you using M2c quick change mount? I always run both braces. Zero problems with the stock mount.
Old 07-18-2016 | 11:32 AM
  #1535
Yup, still using the QC...... I'm using the 48t....never tried the 46 tho
Neesh is offline
Old 07-18-2016 | 11:51 AM
  #1536
bypass911's Avatar
Wierd, my NB48.3 is fine with the QC with 46t.
Old 07-18-2016 | 12:07 PM
  #1537
Hmmmm....maybe try switching the engine mounts from the buggy....maybe something is wrong with the one you used in truggy?
Neesh is offline
Old 07-18-2016 | 01:04 PM
  #1538
bypass911's Avatar
Yeah my thoughts exactly, will try that thanks.
Old 07-19-2016 | 03:04 AM
  #1539
bigbenmbx7t's Avatar
ive got about a gallon on my NT48.3 with the QC from M2C and its been fine. running the stock spur. Maybe its a diff bearing/brace problem? that's weird it works with stock but not with M2C ive had a lot of their products and always have been happy.
bigbenmbx7t is offline
Old 07-19-2016 | 03:07 AM
  #1540
So I ran a trophy race last weekend and im having some issues with the rear end being loose no matter what I do. Has anyone found a good setup for a medium track usually hard packed and ran dry/damp at best. Im trying to get this truck to drive from the front like my MBX7TR and I cant seem to make it work. If anyone has a setup they like a lot id like to see it and compare where im at.
Old 07-20-2016 | 05:13 PM
  #1541
bypass911's Avatar
bigbenmbx7t, what's the run time on your gold paloma .21 on your truck? What size restrictor?
Old 07-20-2016 | 09:21 PM
  #1542
A lot of wheel spin about 745-8 running about 260. I got 930 out of it at 264 in Spokane on a very high grip track.
Old 07-20-2016 | 09:23 PM
  #1543
6.5 restrictor. I've got about 4-5 gallons on it now. Best engine I've ever owned. Gonna order 2 when I get my bonus next month just to have before they get discontinued.
Old 07-20-2016 | 10:26 PM
  #1544
bypass911's Avatar
Cool thanks for that info! I gotta try one myself. I'm barely getting 7 minutes on the roma with a 7mm restrictor and I want at least a minute more.
Old 07-21-2016 | 08:02 AM
  #1545
Have you tried Joe Bornhorst AMS 7.0 setup? Also, if you are getting a lot of wheel spin, you may try softening the clutch a touch. That may help with fuel mileage too.
qstorm777 is offline
