Like Tree12Likes
Tekno NB48
Old 03-16-2014 | 05:22 PM
  #961
Originally Posted by andyhitman
is it this one the FTW00048
FTW00033 is the one you want.
mr240 is offline
Old 03-16-2014 | 07:09 PM
  #962
YANMAN's Avatar
Originally Posted by Jtipsy
Question, im going to be running the xp digital 1015 servos is that enough torque for the nitro buggy steering or should i go to a hw servo with a faster speed and more torque.
I have run the 1015 in the past and they are a good option. I don't think they are high volt servos however. I personally run KO servos at 7.4v now and will not run anything else.
YANMAN is offline
Old 03-16-2014 | 07:32 PM
  #963
DBL15's Avatar
stock body is fine and takes a fair bit to make it spilt at all
i have been using mine every 2 weeks since i got this buggy way before christmas
the FTW body i have ready to go as well is thicker for sure
but the stock is fine
DBL15 is offline
Old 03-16-2014 | 09:54 PM
  #964
vandalzzz's Avatar
On some underhood pics i see rubberbands as return springs, in addition to 'regular' springs from the kit. Why someone decided to go with such 'tuning' option?
vandalzzz is offline
Old 03-16-2014 | 10:22 PM
  #965
JsK's Avatar
JsK
R/C Tech Elite Member
By kit springs I am assuming you mean the springs on the linkage? These are to keep the linkage centered and following the servo arm during movement. A
"throttle band" is there to pull the carb slide and linkage shut in the event of a power loss.
JsK is offline
Old 03-17-2014 | 02:58 AM
  #966
Hoese37's Avatar
That's what I run in mine. They seem to have perfect specs for nitro 1/8. Ran them for 3 years in a truggy and still going strong.
Hoese37 is offline
Old 03-17-2014 | 05:12 AM
  #967
Bernard_Jr's Avatar
Originally Posted by wallride14
Having some trouble getting my blue ofna box to work. Its been used before so the wheel is worn down to 74mm instead of what it is new (76mm). But I don't think that's the problem because the wheel is being stopped by the chassis and I would think a smaller wheel would fit up in the slot further and make contact with the flywheel easier? I definitely don't wont to grind out the slot/chassis to get it in there, but the flywheel seems really raised. What other starter boxes are guys having luck with?
I had to do what mr240 explained. Switched the brackets and drilled a new hole to close the top. You'll notice the pegs shifted to the left as well. I've also added rubber tubing to the front right peg to tighten the fit up.
Bernard_Jr is offline
Old 03-17-2014 | 10:02 AM
  #968
Thanks. Got it lined up and turning over now. But my rear pegs aren't on the box. Am I missing something there? Have to customize your own?
You switch sides the brackets are mounted to. I had some issues getting mine lined up also. The car sits to the left more than other cars.
masher81 is offline
Old 03-17-2014 | 12:17 PM
  #969
Bortzilla's Avatar
Does anybody run the Outerwears Performance Pre-Filter Air Filter Covers? If so, which size fits the NB48? Is it this one:
http://www.amain.com/product_info.ph...-5-8-Tall-Blue
Thanks.
Bortzilla is offline
Old 03-17-2014 | 12:29 PM
  #970
Jtipsy's Avatar
Ill be running a li fe receiver pack in my buggy, as i have several already have them. Hoping to get my buggy ordered by the end of the week.
Jtipsy is offline
Old 03-17-2014 | 01:13 PM
  #971
Thanks.
this one should fit
http://www.amain.com/product_info.ph...ted-RC8-Purple
andyhitman is offline
Old 03-17-2014 | 02:14 PM
  #972
Originally Posted by Bernard_Jr
Attachment 1177964
Ahhhhh... I see the problem now. My box is about 6 or 7 years old. both brackets only have a single slot and not the 3. I'll have to see if I can order that bracket. Thanks for the picture.
wallride14 is offline
Old 03-17-2014 | 02:47 PM
  #973
G SquareD's Avatar
Use caution when ordering the outerwear. I couldn't find a exact fit and called them to review the exact measurements and they recommended they create a custom outerwear to insure it fits properly. I did however switch the stock (Ofna) filter to Mugen MBX7 filter instead. (Easily available pre-oiled bulk filter from Amain).
Moral of the story...a call to Outerwear directly might be well worth it before you buy something you can't use.
G SquareD is offline
Old 03-17-2014 | 02:52 PM
  #974
G SquareD's Avatar
Originally Posted by teknorc
Looks sharp. Love the FTW bodies. Hoping they make one for the NB48 sometime.
I contacted FTW directly about 1.5months ago and they advised they did have plans to develop a body specifically for the NB48. Hopefully we see something soon :-)
Old 03-17-2014 | 10:01 PM
  #975
vandalzzz's Avatar
All three diff cases have very-very tight fit into metal spur gears. Is it ok, anyone experienced same 'feature'? Should i grind some plastic with sandpaper?
