Like Tree12Likes
Tekno NB48
Old 02-18-2014 | 11:25 PM
  #766
DBL15's Avatar
Originally Posted by BigPar
Noob question, how do guys adjust the brake bias so it is 40f 60r?
The little tie rod mate just make it longer or shorter to suit your bias you want.
DBL15 is offline
Old 02-19-2014 | 06:53 PM
  #767
BigInJapan's Avatar
Nice customer service thanks Tekno RC!
BigInJapan is offline
Old 02-20-2014 | 06:52 AM
  #768
Numburn's Avatar
That's just an estimate.
http://www.youtube.com/watch?v=Wsd8o0Am_qc
Numburn is offline
Old 02-21-2014 | 07:54 AM
  #769
Tekno,
A little feedback on the NB-48 (First Tekno kit)....
Thank you for pre cutting the decals.
carry on.
masher81 is offline
Old 02-21-2014 | 11:18 AM
  #770
BigPar's Avatar
Originally Posted by Numburn
Thanks Numburn!
BigPar is offline
Old 02-23-2014 | 09:15 AM
  #771
Just like to say had my NB out today even to the weather was against me,,,, and it is the fast buggy i have driven on wet astro, loads of on off power and cold really push it into the corners and power out again roll on next weekend's race day
again thanks tekno for a really smooth fast buggy keep up the good work
tank issues NONE maybe it was cos i put rubber insert into the holes on the tank, and since i have had this i have never had any screws come out which is a very very good thing
andyhitman is offline
Old 02-24-2014 | 09:22 PM
  #772
well just to ask, has anyone broke the rear diff case where the chassis brace bolts to the case? with a gallon on the car a broken tank and case are the only two breaks I have had. ill post a pic in the morning and email tekno as well, I know the rear bulk heads were breaking but the chassis brace mounting point is a first for me.
bastard dsm is offline
Old 02-24-2014 | 10:24 PM
  #773
Going on 3 gallons and not one broken part. And I have had some big crashes.
mr240 is offline
Old 02-25-2014 | 07:47 AM
  #774
I haven't broke the rear diff case, but I did put a longer screw, just a few millimeters, stock one strip the diff case a little bit.
I’m really happy with the nb48, except the way you bolt the chassis brace on the diff case, and of course the nipple inside the tank, definitely needs more barb and a longer one. But like I said longer screw on the chassis brace is doing the job perfectly.
jvcabezas is offline
Old 02-25-2014 | 10:54 AM
  #775
yea, thats what im going to do when I replace the case. the buggy is awsome and responds to every setup change, also the tekno 1.3x8 pistons are nice. I dont even want to try kyosho pistons, the only thing is I think the front pink spring is too soft and the red rear is just about perfect.
Old 02-25-2014 | 12:05 PM
  #776
Swap out the pink front for yellow.
mr240 is offline
Old 02-25-2014 | 12:37 PM
  #777
im using xray 3 progressive springs, buggy is on rails and im using 1.3x7 hole with 32.5ae front and 1.3/1.4x8 hole 27.5 ae rear. soaks up everything and is susper stable, here is a pic of the case.
Old 02-25-2014 | 01:26 PM
  #778
my current setup
Old 02-25-2014 | 03:45 PM
  #779
Indy is very cold inside usually and very hard. I broke my case in the same spot at Indy....you can put a little longer screw and it should help. Just make sure you dont over tighten. I am using a couple mm longer screw
PUDDIN is offline
Old 02-25-2014 | 04:30 PM
  #780
Some pics from Nitro Challenge last week..
PUDDIN is offline
