Tekno NB48
#3031
Another thumbs up for this buggy!
Built mine 2 days ago, raced it today (haven't drove a nitro buggy in two years) finished 5th in the A today. Stock setup except for 6x1.5 pistons. Indoor clay. Build was typical Tekno flawless.
Cant wait for spring to get it outside!
#3032
Anybody know if they're coming out with an updated NB48? If you go on their website and let it scroll through automatically it's the only kit missing unless you go under kits or scroll all the way down it's there, but on the main page it's not on there?
#3033
#3035
So, i think its time to ask here:
NB and EB owners, please help
I have both buggies and two sets of CNC shock pistons: 6x1.5 and 8x1.3. Which one i should place into EB and which one should go into NB? Tracks here ususally med to high bumps, small jumps and many 180 turns.
#3036
I have both buggies and two sets of CNC shock pistons: 6x1.5 and 8x1.3. Which one i should place into EB and which one should go into NB? Tracks here ususally med to high bumps, small jumps and many 180 turns.Either work well. Im sure you could use all 8x1.3 also just have to adjust your weight of oil.
#3038
does this battery work on the buggy? anybody using it? can foam be added to prevent movement?
http://www.amain.com/reedy-flat-li-p...200mah/p268575
thank you.
thank you.
#3039
thank you.
thank you.
#3040
One more question about shocks: what is the best way to polish stock shaft? Dremel with special bit and paste works ok?
#3041
http://www.tytessman.com/racing/tips...oth-shocks.php
Regards,
#3045
This is what I use and it is great fuel line. Comes in a plethora of colors and is available at most hobby shops.
http://www.amain.com/du-bro-nitro-li...ue-61cm/p13003
12Likes
