Like Tree12Likes
Tekno NB48
Old 07-24-2014 | 04:57 AM
  #1831
videos to come!!!
Mo Denton is offline
Old 07-24-2014 | 06:52 AM
  #1832
offroad dude's Avatar
Originally Posted by Mo Denton
videos to come!!!
Were waiting...
offroad dude is offline
Old 07-24-2014 | 06:53 AM
  #1833
Is there another brand piston that will fit to achieve 6 by 1.5 piston. How are you modifying current pistons.
eddie10 is offline
Old 07-24-2014 | 07:27 AM
  #1834
Jtipsy's Avatar
I bought a set of ae tapered blanks to make mine. They are pre dimpled to ease in drilling.
Jtipsy is offline
Old 07-24-2014 | 07:51 AM
  #1835
Cappy's Avatar
I would also love to see an alum throttle horn
Cappy is offline
Old 07-24-2014 | 08:15 AM
  #1836
im assuming kyosho pistons will fit then?
eddie10 is offline
Old 07-24-2014 | 09:04 AM
  #1837
FastPete's Avatar
+1 Im sure their listening.
FastPete is offline
Old 07-24-2014 | 10:38 AM
  #1838
teknorc's Avatar
Originally Posted by JsK
Thanks for bringing out great new products like that Danny. Have you tried
the LRC plate on the truggy? And are there any plans for a aluminum throttle
horn?
We run the LRC plate on all of our vehicles. Helps everywhere.
No plans for an aluminum throttle servo horn at this time. We really haven't had a need for an aluminum version. We'll keep an eye on it though, others have requested it. The issue is that we have to make 3 different versions of it and the production minimums and stocking them all for a small expensive part is hard to justify. Especially when the stock horn works so well.
teknorc is offline
Old 07-24-2014 | 11:07 AM
  #1839
Is the LRC block basically lower the inner hinge pin? Could this be accomplished by making a pill that slam the hinge pin in the current toe block? Just tryin to visualize what the lrc block does.
underway is offline
Old 07-24-2014 | 11:26 AM
  #1840
teknorc's Avatar
Correct. This part was based off of the BMI LRC inserts. The only issue with the inserts were not enough material around the hinge pin and only center dot was available. So with the new LRC block, you use the stock inserts and have full adjustability. You can use the BMI inserts in conjunction with the LRC block and get it really low.
teknorc is offline
Old 07-24-2014 | 12:12 PM
  #1841
JsK's Avatar
JsK
R/C Tech Elite Member
Yes the stock horn works great, until you take it off and on a bunch of times. Gets a little loose on the servo then. No problem though I will just make sure I have a spare set of plastic ones on hand.
The pills do the same thing but I went through this with my AE car and a new toe block is a much easier solution. It's not cheaper up front but it allows you to use the inexpensive pills instead of having to buy the Low RC inserts in all the different dots.
Yes Danny you could combine this with the LRC insets but it gives a ton of anti squat at that point without a lower anti squat plate. A bunch of anti squat along with the LRC is usually counterproductive . At least it was on the AE car. Maybe the tekno would react better.
For people planning on using this it also changes your anti squat so if you have a setting you like you will need to drop it one dot along with the plate.
JsK is offline
Old 07-24-2014 | 02:52 PM
  #1842
Anybody know if there are internal different shims from another manufacturer the will work. Mine are bad and updated ones are in the mail
eddie10 is offline
Old 07-24-2014 | 04:38 PM
  #1843
Mugen ones will but need opened up a little.
Old 07-26-2014 | 03:30 AM
  #1844
Casketman's Avatar
Nice 10x20 Tekno tent set up at the Futaba/OS Challenge this weekend at Dirt Burners RC outside St.Louis this weekend!(photo at the bottom of the page)
http://www.rcnews.net/2014/07/25/201...tro-challenge/
Casketman is offline
Old 07-26-2014 | 03:46 AM
  #1845
Casketman's Avatar
Has anyone used the Aluminum rear drive shaft? I just replaced my twice bent stock drive shaft so I wonder if the aluminum one is any better.
