Team Associated RC8B3 Nitro Team Kit
#3991
Answer.
Fish tail at off power u can have from thinn oil front too.cause the wheels its so free when u let the throttle and u have more entering steering.
#3992
Has anyone tried the Losi lightweight spur gear??? Curious if it fits on the center diff. Maifield mentioned he runs one in his Truggy with an AE clutch. Says its a better mesh. But i like the idea of a lightweight spur.
https://www.amainhobbies.com/losi-48...osa3556/p34982
#3993
[QUOTE=TOO-TALL;15469239]Curently running 7,7,5 with underdrive fron and rear.
Conditions
Lose, dusty
My problem.
When I let off throttle the car gets to fish tailing.
Center fluid to heavy?
I checked to see if I had a stuck bearing.there fine.[/QUO
my buddy went from 775 to 10 10 5 and says it alot better
Conditions
Lose, dusty
My problem.
#3994
Answer
[QUOTE=DPowers;15474263]
Go with 6 5 3 and diff fill exhatly like manual.and u will see how stable will be at on power and off too
Conditions
Lose, dusty
My problem.
Conditions
Lose, dusty
My problem.
#3995
I have run losi gears on AE diff cases.. It's not a perfect fit, so it's up to you. Will it work, yes.
Is it needed? Not unless you're changing ratio.. Better mesh, only works for the top 5 guys.
#3996
Hi, does anybody run or have tested extended/offset:ed shock mounts / shock bushings? what did you found out? any difference in handlings?
Example https://www.amainhobbies.com/psm-ass...m02064/p966548
#3997
Thinking about using the LTC gears in the rear. What would be the effect of running both the LTC internal gears and the underdrive gear set? This would be for a larger outdoor track with low traction.
#3998
Guess this thread flamed out?
#3999
#4001
Could someone please messure the with of the rear diff? Ouitside bearing to outside bearing, Thank you :-)
#4002
The AE springs seem to sag over time. I have to put more and more preload in them to keep the ride height, particularly in the front springs. The grey and white AE front springs out of the bag I had to basically crank the preload all the way down the shock body, just to get a ride height that was acceptable, but not as high as I would have liked.
Based on the advertised spring rates the 9.25X70mm is between the grey and white AE front spring, and the 10.75X86mm rear is basically the same as the rear AE white springs. I was running the AE blue front and AE white rears before.
The track was new when I put the Mugen springs on and I have not done a back to back yet between the AE and Mugen springs. I did go to a stiffer front sway bar though with the Mugen springs to get some more steering. I may try the next stiffer front Mugen spring, but the rear seems pretty good.
