Team Associated RC8B3 Nitro Team Kit
#3798
Can you use Losi clutch shoes on the AE flywheel.
#3800
#3801
AE has posted Ongaro's worlds setup. The C and D block pill positions are interesting. Is he running toe OUT on the rear?! https://www.teamassociated.com/pdf/c...0URVEw1JvbgC_s
#3802
#3804
#3805
Lots of antisquat and very little toe wouldnt this be ultra agressive off power in the rear unless you are running allot of roll? Would probably be super predictable under power tho and a grab of throttle should straighten it out pretty good if you get too loose off power.
#3806
Ongaro's setup is 1° toe-in and 2° anti-squat.
I would imagine this setting has to have the quickest rotation possible but very hard to control side bite.
It actually makes sense when you look at Ongaro's car. It often looks like it rotates completely on the front end and the rear has broken traction completely.
I'm surely going to try it, but I wouldn't be surprised if it was truly a pro-only setup .
#3807
Ongaro's setup is 1° toe-out and 2° anti-squat.
Stock is 2.75 in so I'm pretty sure its 0.75 toe in.
#3808
I notice it doesn't have the Mugen rear hubs or mugen spindle. with spacer. Does anyone if they were AE proto-type parts ?
