Hot Bodies D812
#6601
Yeah that's been commented on before and yeah it gets sloppy. Torrance mentioned that that was taken into consideration in the design or something like that so the car drives the same new or old. IMO you can't be too anal about somethings (like some slop) or you'll go mad changing hubs, arms, bushings, collars, knuckles, kingpins and spacers every month.
#6603
#6605
#6606
Has anyone used the d815 gear box for the d812 internals ? The reason I'm asking is because there's a video of Ty's 2014 neobuggy car and it looks like he's using a protype version of a 15' gear box with Verza rtr parts , but I could be wrong if anyone knows could they chime in thanks
#6607
#6608
Ty's '14 Neobuggy car - Actually uses a D812 gearbox that was 'shaved down'
* A new 10T input gear that will be compatible with the D812/D8TTE ring gear and D815 gearbox is yet to be released though will not work with the Vorza rtr center shaft parts.
#6609
thank you I appreciate the quick response and good info.
#6610
The gears that have changed, are the pinion gear, and the ring gears, the gears in the diff cup are all the same.
#6611
thank-you can someone explain which situation I would want to be using the long swaybar set HPI68191 compared to the short swaybar set HBS68188 because Im not sure which one to order never had the option of long or short before or I can go with the d815 sway-bars
#6612
For the d812, you use the long sway bars in the rear and short in front. On the d8t, you use the long sway bars on the front and rear. The d815 has sway bars that are bent differently and also come in a long and short version.
#6613
I'm almost 100% sure u could use D815 bars on the D812.
#6614
Yup. They fit no problem.
For anyone that's curious, the d815 sway bars only fit on the rear of the d8tte. When I used the d815 long sway bar on the front of the d8tte, I had some clearance issues with the steering turnbuckles.
#6615
Follow up ...
The experiment was to run the D812 like D815, since D815 will be using taller gearing (43/13). I was all positive that this will work. Since trophy is using the same diff case, bulkhead, bearings as D812, thought would be perfectly fine to use the trophy buggy bevel gear. There was not enough room to fit in the D812's diff gear inside the bulkhead. I totally overlooked the diff ring that there was a difference between the two. Well, I guess just get the trophy buggy's complete diff assembly to run like D815 gearing but it's going to be on a heavier side since its ring gear is not lightweight. Just a stupid idea of mine would like to share.
The link above is directly fit to D812 if you are wanting to get the gearing of D815 which is (43/13), ring gear and pinion respectively. Just buy 2 of them. Along with it, just buy the 110 mm dogbone and 83mm dogbone from HPI Vorza. To me, that's the only biggest changed has been done to D815. Of course, you gotta get the 13T CB.
Cheaper way to upgrade your gearing ratio. I did this and been racing with it... I'm one happy camper.
