Mugen MBX7
#4489
pressure line : coming from the pipe put a loop in the pressure line, after the loop put a fuel filter in without the screen or stone, then plug into the tank.
I did that and didn't have any issues with my engine after pits this weekend. I'm not a fluid / gas dynamics engineer but my understanding is this allows the pressure to equalize and gives the fuel a place to sit if it get pushed back into the pressure line when the fuel lid is snapped close with out blocking the line.
#4490
I think it has more to do with the lid causing excess pressure in the tank, and forcing more fuel to the carb.. But I may be wrong. I'll try experimenting with some stuff. It does seem more prevalent when pushing the fuel window. What baffles me the most however, is the fact I've NEVER had this problem before this weekend.
#4491
Is this problem with the updated tank?
#4492
Is anyone running a B6 pro in there 7?... What is your fuel ecomomy like?..one of the tracks I race at you're on the gas a lot and i'd be lucky to get 8 minutes on a tank, and thats driving to not use too much fuel, home track is more technical and good for 9 minute tanks, my Werks team mate with a XB9 does the same lap times but gets a minute longer tanks, is the mugen thirstier on gas than other buggys.
#4493
#4494
that is the weak spot on the rear imo..i have bent mine on the 7…luckily not that much..so i could bend it straight in a vice again. on the 6R i have broken that version of this part. it breaks right where it gets machined out. it does take a very specific tumble/hit to bend/break that though. i noticed the bend on my 7 the one day when i was rebuilding. and saw some play in the rear arm even though the spacers were there. The toe insert was torn a bit and it seemed like the hinge pin and all transferred all the stress through to the rear/front mount there…and bent it forward on the one side. i guess it happens when someone rear-ends you smack bang on the arm or something. The rear brace/ mount is strong though.
tryed to bend mine back at the track but broke it
#4495
Same here... Qualified into the semis at our national and flamed after every pitstop because of that, I couldn't drive the main final.
#4497
Are you guys boiling your arms prior to building? I have some people telling me here locally to boil my arms. Just curious
#4498
#4499
#4500
When I was building my kit, a good friend advised me to do the following
