Mugen MBX7
#4366
It was with a bottle. I'll do some pitstops for myself the next time I'm going to practice and try different methods.
I have my fuel line like that. With an exhaust cooler in the middle.
The first time it died at the end of the pitlane. He overfilled my tank and some fuel spilled.
The second time I could see it clear because there was so much smoke in the tank. But this time he didn't spill any fuel. I was a little angry from the first and I WOT'ed very aggressive after the refuel. The engine didn't rev when it did that. It died immediately.
#4369
Golden. Always grease em.
#4371
#4372
#4373
That is definitely not normal. I would take it apart and do it again. Remember, only use the 2 o-rings for the large gears. Don't use the small o-rings for the 4 small gears. Also, make sure the o-rings are seated properly.
#4375
Are people using the short or long chassis brace for the front?
#4377
i run long brace
#4379
M2C RACING WING WASHERS FOR THE MBX7
M2C RACING is pleased to announce our new WING WASHERS for the MBX7
These are designed for the unique design of the 7 wing to allow you to run
centerline or and offset wing.
These washers are made with 6061 material and anodized black and bright coated to
add a little shine. This model also will accept a socket head cap screw
button head or a flat head screw
2 centerline
2 offset models are included in each pack.
http://www.m2cracing.com/searchquick...?keywords=5294
www.m2cracing.com
