Mugen MBX7
#3348
not 100% sure, but ...
F is for example for Futaba, which is 25T.
S could be Sanwa, which then would be 23T
K also could be H for Hitec ???
==> finally you need 24T for Hitec servos.
do not have a Mugen currently.
but in my Sworkz, servo horns are named F, S and H
found that from Robitronic ( Austria )... could be a help:
(23T) KO, Sanwa, JR, Airtronics, Graupner, Mulitplex
(24T) Hitec
(25T) Futaba, Thunder Tiger
(24T) Hitec
#3349
My kit has the clear tank as well. I called Mugen and
They said that the reason why they are breaking is people are not mounting them correctly. They should be 2mm office chassis, not tightened all they way down.
I'm not that far into the build yet so I'm not exactly sure how this would work. But that's the info straight from the company. The clear plastic is somethig they use on their on road cars so it's lighter weight and not as durable. After all the issues with improper installation they have went back to the hard material so when the are tightened all the way down the chassis flex does not break them...
2mm that's supposed to be the spacing..
#3351
I have Hitec 7955TG servos for steering and throttle. When putting together the radio tray, which insert do I use, the F, K or S (part E2303)?
For both servos, you use A on one side on the other you have to choose. I noticed they are all slightly at different lengths from each other by half a mm or so.
When put onto the tray there wasn't that much difference and they seemed to have held the servo OK.
Does it really matter which one is used?
#3352
soar Seiki SR21TRS
http://www.soarseiki.com/sr21trs-tuned-edition-2/
Tom you know anything about these motors
#3353
Just wanted to make sure in case it somehow puts stress on the servo and burns it out or the part comes loose after a while if on an angle or something.
It would be nice if the manual was be a bit more specific!!
#3354
Never mind, wrong answer.
#3355
Broke my OS Speed XZB Spec II in today and painted my body. First time I tried something different than a 1 color body.
#3357
Not much on aftermarket parts, but this one speaks for itself.
Very nice fit, however, watch your screw length in the 2 bulkhead screws and the chassis brace screw. This top plate is thinner where these screws mount, making a longer screw possible to bottom out.
Also the standard top hinge pin shims made for a tight fit, causing a bind. I guess I had some 0.9mm shims leftover from the x7 build. Replacing the rear most 1.0mm shim, with the 0.9mm shim freed the upper arm up.
#3358
it 's similar at fast race!!!
#3359
More stable high speed turns
