Team C Racing's T8 Nitro Buggy!
#691
Yes I run vp and this one has about 5 gallons on it
#692
It's leaking at the seam. This second tank I hot glued it up but seems like front post is hitting the tank and making it leak again. Went to LHS and have them fixed yesterday. Will see if it's holding up in today race.
#693
Nope havnt had that problem yet after 2 years of running for team c
#695
How are the Kyosho springs compare to stock springs? The Kyosho springs are too expensive for me to order them for just trying.
#696
New tank is only about $15 so I ordered spare just in case.
#698
#699
Kyosho springs made the biggest difference.And Scott,are u running on a high-bite surface??
#700
Since I heard a lot about these springs, I might give them a try. I will need these two, right? And do i need to change anything else in order to use them?
Kyosho 70mm Big Bore Front Shock Spring (Light Blue) (2)
Kyosho 84mm Big Bore Medium Length Shock Spring (Light Blue) (2)
#702
