Team C Racing's T8 Nitro Buggy!
Good job Ken! Thanks for the support!
https://picasaweb.google.com/axel.to...eamCT8Building
pictures of building and a review of the building process:
http://translate.google.com/translat...t8-18-krossari
it is in finnish so the google translation is probably not the best.
Heard a lot of good things about T8..
Quite big in where I live..
getting mine in 2 weeks time.. Cannot wait
Just letting u team c guys know ive a team c buggy brand new for sale if you guys are interested...If your reading this thread im sure u know that these cars are really good out of the box. Heres the link
http://www.rctech.net/forum/r-c-item...brand-new.html
I make the two shocks the same length and then set the droop screws so that they touch the chassis just before the shock piston bottoms out.
Ride height... rear arms level and front just a bit lower than rear.
i have another set up i think some may like:
most of set up "Stock"
piston and oil Front "White" 6 hole 40wt
piston and oil Rear "Black" 6 hole 27.5 Losi
Diffs a 5K-5K-2K
2.3mm sway bar front and rear
droop center to center on shock front 96.5mm
droop center to center on shock rear 106mm
Higher traction track more "Flowing" and Smoother
piston and oil Front "Black 6 hole Drilled" to #55 w/35wt.
piston and oil rear "Black" 6 hole 30wt.
Diffs 5k-7k-3k
droop center to center on shock front 95mm
and "Truggy Soon".....
Diffs a 5K-5K-2K
Diffs 5k-7k-3k
well maybe i should explain where i measure from...my bad...
i took the measurments from the "Center" of the shockcap eyelet
to the Bottom shock shaft eyelet.......
same way they measure on the Ae,Losi's and Mugen's
for example, on the "Set Up sheet"
you'll notice where on one of them it has the Measurment of
110 for the front and 129 for the rear....
I'll post a pic here in a few....
there are seveal ways to measure so i should have maybe explained it a little better..
sorry everyone....
but can also some will measure say from a rim with no tire on it,and measure from Axle down or up etc.
i hope this can help Clairify, if any Questions let me know..
sorry everyone....
