Pre Heating Engine
Old 06-14-2010 | 07:20 AM
Default Pre Heating Engine
I am about to start breaking in my new engine. Just wondering how are people preheating engines when they don't have access to a power outlet. I have a power invertor in my SUV but it is too small to run a heat gun. Any suggestions.
mr240 is offline
Old 06-14-2010 | 07:48 AM
secretsg's Avatar
Body heat
or this
http://www.competitionheat.com/
secretsg is offline
Old 06-14-2010 | 08:04 AM
find power. somewhere somehow. you do NOT want to try and break in a brand new motor without preheating. you will shorten the life of that motor like crazy
skoalisbad4me is offline
Old 06-14-2010 | 08:09 AM
John.C's Avatar
I use Competition Heat to achieve proper/optimal engine temps prior to startup. Prior to using this product I used a heat gun. My local track also does not have available power so I'm currently looking into an alternative power source solution (power inverter and stand alone units) to power up my engine heater. In addition to the link provided above you can also check out this conversation on rctech.
John.C is offline
Old 06-14-2010 | 09:17 AM
Quad Racer 34's Avatar
you don't want to start that engine without preheating it first for break in. I always preheat my engines. I have 5 or 6 gallons on my practice engine and STILL pre heat it before I start it up. and it still has a lot of pinch. it definitely lengthens the life of the engine imo.
Quad Racer 34 is offline
Old 06-14-2010 | 09:22 AM
Roelof's Avatar
At a gas station or a truck stop you will find 12v hairdryers. Maybe not enough heat but it is a way to give the engine some heat.
Roelof is offline
Old 06-14-2010 | 09:37 AM
Maximo's Avatar
+1
As well a preheated engine is much more stable for tuning....
Maximo is offline
Old 06-14-2010 | 11:39 AM
mugenize1's Avatar
If you don't preheat the engine it will shorten the life of your con rod as well. the bushing in the rod will give out it happened to my V-spec a brand new one at that
mugenize1 is offline
Old 06-14-2010 | 12:01 PM
CompetitionHeat's Avatar
CompetitionHeat is offline
Old 06-14-2010 | 12:11 PM
neobart's Avatar
Originally Posted by CompetitionHeat
There's something wrong with your webpage.
neobart is offline
Old 06-14-2010 | 12:21 PM
Thanks, lets try this again... http://www.competitionheat.com/
Old 06-14-2010 | 12:29 PM
neobart's Avatar
d'oh.... I didn't notice the link added the nod in the end.
neobart is offline
Old 06-14-2010 | 02:54 PM
keep heating until the pinch is gone.
dreaux is offline
Old 06-14-2010 | 03:20 PM
I prolly get a posse chasing me for giving this advice, but what the heck:
I've used a creme-brule torch together with aluminium foil. Beware of where u point the thing and not putting the flame directly to the engine (hence the foil).
If youre careful its no problem to slowly heat youre engine to the required 150 - 200F, better than cold starting youre mill.
Heat gun is still my choice (waiting for the competition heat 230V version)
casevac is offline
Old 06-14-2010 | 03:27 PM
pntmachine's Avatar
Comeon' no flaming in this thread
pntmachine is offline
