Ask Aaron Waldron
#901
My dad really likes using Hydra-Drive fluid on tranny gears..but good luck finding any of it hahaha.
vengence - What kind of noise is it?
#903
Aaron, do you prefer to use ballcups or closed end connectors (i.e., Rocket City) on the rear camber links of your gas truck?
#904
im not really sure its kinda of a electic winding sound almost i cant really explane it
#905
Aaron, I am just wondering why my truck is so loud, its a xxxt mfe, and I was wondering what I might do to make it as quiet and as smooth possible, what should I do?
#906
I am looking for a good steering servo for my new Losi XXX-T MF.
I have access to Futaba, airtronics, HiTech and multiplex.
should i go for Digital or analog servo ??
I just need something that will last and is quick.
What would you guys recommend.
Plz comment.
Plz comment.
#907
servo?
the aitronics 94357, and the hitec hs925d are close in characterictics. both over 100 oz. torque with speed under .09 . the airtronics is more money and maybe better quality. I run the hitecs with no problem what so ever. If you want their brothers you could go with the 94358 or hs945d these are a little slower but have more torque. still plenty fast though.
#908
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
whic ON-ROAD tyres and inserts should i use?
AARON,
i dont know whether i can ask you about this one or not...
i think i will run my buggy mostly on-road for the time being... coz the 'grass track' we ran our buggy is actually a public park and one of these days i think a policeman or safety GUARD will wait for us at the 'grass track' for us to SCREAM at us because we had killed the grass at the park....
so i think i will run more on-road with my buggy. I LOOOOOVE them....
OK...
searched TOWERHOBBIES... about on-road buggy tyre... but a few questions:
i know you cant click the links that i provide...
ok go to www.towerhobbies.com and search my items listed down there to view the items pictures.... thanks!!!
is this cool?
http://www2.towerhobbies.com/cgi-bi...=LXFBV8&P=0
DuraTrax Street Trac Buggy 1/8 (2 pcs)
and which inserts i should use?:
either this one:
http://www2.towerhobbies.com/cgi-bi...=LXPR98&P=M
DuraTrax Foam Tire Inserts Axis (2 pcs.)
or this one?
http://www2.towerhobbies.com/cgi-bi...=LXNX12&P=M
Pro-Line 1/8 Impact Firm Insert Buggy (2 pcs.)
in tower hobbies, they listed down the things that most of the buyer of the on-road tyre will buy those kind of inserts... but i am confused which one is good.
also they aer recommending to buy this one:
http://www2.towerhobbies.com/cgi-bi...=LXPS34&P=M
DuraTrax Shock Diaphragm Axis/Nitro Quake/T Quake (2 pcs.)
what is that for?
how to use that?
one more... is there any other on-road tyre design? i dont like the tyre thread on the tyre shown at the top in the towerhobbies website.
thanks....
mop
OK...
is this cool?
either this one:
or this one?
what is that for?
how to use that?
thanks....
mop
#909
Servo Choice
Paul is not sponsored by any electronics company. We know it's expensive, but he runs 94357 in all his vehicles. Fast, strong, reliable. That's what you need and that's what you get. Period.
#910
Re: Servo Choice
This is what I found at Towerhobbies.com
Is this what you mean ?
Airtronics 94357Z ERG-VR Hi-Speed/Hi-Torque 125 oz/in
Will this servo do the job for years to come !
#911
mop-iko,
try out this place, a better selection of higher quality street treads for buggies. they are a good place to deal with too.
http://www.nitrohouse.com/1_8_on-road_tires.htm
hope that helps
hope that helps
#912
Originally posted by corradopsi
mop-iko,
hope that helps
mop-iko,
hope that helps
mop
#913
L. Fairtrace - The Hydra-Drive helps on really rough and slippery tracks..sometimes I wish we were still running it..hahaha
Brownie - I run Losi's new white ballcups. Closed ends are great..but if you break one, you're done. My pit man always brings extra camber links with him during a long main, so they can be replaced quickly if one of the ballcups breaks.
vengeance - Is your gear mesh set correctly?
rc10t3 - Usually, those noises are made by incorrect gear mesh. Use a piece of paper in between your pinion and spur gear to correctly space out the teeth, tighten the motor down, and then slide the piece of paper out.
It could also be the gears in your transmission. Use a little bit of the white assembly grease from your kit on the gears of the tranny, and spin it through to lubricate all of the gears.
snikkari - I use Airtronics servos exclusively...if you're going to spend money on your own electronic equipment, make sure you get the best. I use the 94357 for steering. It's fast, has good torque, and centers very consistently. The link your provided is the 357 with the metal case..which is perfect!
mop_iko - Pro-Line makes a Road Hawg 1/8th scale tire that works great. As with most on-road tires, make sure you go up one tooth on your clutch bell to regain the gearing you will lose when going to smaller diameter tires.
#914
that is a COOL answer..... now i know when i am on-road i have to have a smalller clutch bell!!!!! here goes my money !!!!! got to order that one!!!!
mop
#915
No no..when you're running on-road you are going to have smaller tires on. You need a larger clutch bell with smaller tires.
