8T 2.0
Old 02-19-2009 | 05:32 PM
  #1066
J-DUB's Avatar
march 21 at hcrcracing in Danville In. there is a cash race for pro truggy and buggy. check out hcrcracing.com really nice indoor track
J-DUB is offline
Old 02-19-2009 | 05:35 PM
  #1067
Frank L's Avatar
Originally Posted by J-DUB
here is a pic of the 2.0 hub and spindles modded for the 8x16x5 bearings. i used some bearings that were around bocos but i usually use avids. and for those that like the bling kingheadz will be offering rear aluminum hubs with the bigger bearing in the near future. for those who want the stock hubs i will do them for you.
Where did you see the king headz hubs??
Frank L is offline
Old 02-19-2009 | 05:48 PM
  #1068
JAMMINKRAZY's Avatar
+1 I just bought the losi ones. If I had known KHZ was gonna make em I might not have!
JAMMINKRAZY is offline
Old 02-19-2009 | 05:54 PM
  #1069
J-DUB's Avatar
they will be out real soon within about a month or so
J-DUB is offline
Old 02-19-2009 | 05:57 PM
  #1070
Any idea of the price?
Old 02-19-2009 | 07:10 PM
  #1071
I am getting ready to replace the chassis on my version 1 8ight b and am wondering if I can use a 2.0 plate or not. I do realize that it is overall 2 mm longer. Thanks
omaha_racing is offline
Old 02-19-2009 | 07:35 PM
  #1072
losi_racer's Avatar
you can, you need new dogbones(rear) but i think thats all
losi_racer is offline
Old 02-19-2009 | 07:54 PM
  #1073
I think you will also need a new side mud guards, Radio tray and linkage
Signguy Gary is offline
Old 02-19-2009 | 08:12 PM
  #1074
Not if he uses the 1.0 radio tray. If he uses that, he won't need anything other than the chassis and rear cvd. If he wants to use the 2.0 tray he will need the tray, linkage and side guard. I believe the same applies for both 2.0 buggy and truggy chassis'.
Old 02-19-2009 | 08:56 PM
  #1075
RC-BATT's Avatar
Yo J-DUB thanks for hook up on the rear hubs, smooth as butter. Ill get you my front spindles this sunday or monday..
RC-BATT is offline
Old 02-19-2009 | 09:34 PM
  #1076
jldjlaudio's Avatar
Yes you will deffinately need the linkage if you switch radio trays.. I got the 2.0 tray for my 8t and found out after getting it on that my old linkage was too short.. but I didnt order the new stuff i just took off those shorter rods and went to the hobby shop and got airplane linkage that was threaded on one end and cut it to length and put the rest back on from the old stuff.. .Works great and saves some loot. New linkage is like $16 I think.. but I too am going to get the new chassis and rear axle and the shock towers and body and poof itll be almost the same but a couple other things..
jldjlaudio is offline
Old 02-19-2009 | 09:50 PM
  #1077
I just realized that I posted this in the truggy version and not the buggy thread... Oh well, I guess that they are close to the same. Now my other question is I have noticed that they changed part numbers for allot of the parts, but they look identical. For instance the front arms, 2 different part numbers but both look the same. Also the front and rear cvd's are the same way. I can understand the rear center drive since the chassis is longer, but are the other items the same? Also if i changed out the rear hubs to the new version, would I need to replace the cvd's or are the 1.0 the same?
Thanks again for the help. I did the math on doin a conversion and it was about 275, I dont think that is too bad.
Old 02-19-2009 | 11:50 PM
  #1078
The arms are made from a different material, so thats why they have different #s. As far as the chassis you don't have to have the new arms, but you do HAVE to have the new mud guards and rear drive shaft. I would get the new servo tray and likage or make your own linkage.
LosiMadMan is offline
Old 02-19-2009 | 11:55 PM
  #1079
Originally Posted by jldjlaudio
Yeah I think you need them checked because last time I checked this truck has not been sold (8t 2.0) as an electric BUT AS A NITRO!!!!!!!! And when you get more posts and become a mod then come back and check me on what I post where!! ANYONE ELSE ON HERE GET A LOSI 8ight T 2.0 THAT WAS ELECTRIC WHEN THEY GOT IT SEALED IN THE BOX!!! Oh and lastly I was primarily posting about the price that the discussion was about for these trucks!!
What does your post count have to do with anything? I've been in RC for 20 years, but I only have less that 300 posts. Does more posts make you uber cool or something?
Anyways who ever is paying $700 need to shop some where else.
Old 02-20-2009 | 02:06 AM
  #1080
TIX's Avatar
TIX
nice work J-DUB
Did you keep the bearing .2mm proud of the hub. I found that of all the ones I have done over time the ones that sat proud .2mm worked the best. It takes up alittle bit of the play so there's alittle less pressure on the bearings
Hopefully Losi will pull there finger out and start making them as a hopup part. That way we won't have to spend so much time machining them up.
Anyone in the US be sure to contact J-DUB for this mid. If your in Australia and want it done I can get it done for you
TIX is offline
