8T 2.0
Old 08-03-2010 | 09:16 PM
  #8386
JAMMINKRAZY's Avatar
Originally Posted by Frank L
I have seen the video and I understand the physics behind the theory but I still don't see that kinda heat being generated on a 30 min run. I'll definatly check it out. I'll run my truggy for 39 mins like in a main and then take the temp of the shock oil. Who knows I may be surprised. But I don't get the heat part.
Man, I don't know, but any change in air pressure behind the bladder for any reason will change rebound without the vent hole. Say you build your shocks in your cool air conditioned house, and take your ride to the track and leave it sitting in the sun on a hot day for a couple hours. I bet your rebound has changed. If your running vented caps it will be the same or very close.
JAMMINKRAZY is offline
Old 08-03-2010 | 09:23 PM
  #8387
Frank L's Avatar
Ok
Frank L is offline
Old 08-04-2010 | 01:05 AM
  #8388
deadmancourt's Avatar
what is the difference on 0 rebound to 1/2 rebound to full rebound?
deadmancourt is offline
Old 08-04-2010 | 08:35 AM
  #8389
Frank L's Avatar
It's how fast the piston comes out or how far the piston comes out when compressed and no spring.
Frank L is offline
Old 08-04-2010 | 12:39 PM
  #8390
yeah i know that!...i meant what difference does it make on the truck?
Old 08-04-2010 | 01:35 PM
  #8391
token's Avatar
Changes how each tire reacts to impact.
token is offline
Old 08-04-2010 | 01:51 PM
  #8392
so if i am not that smooth yet and the track has a lot of jumps,should i run full rebound?
Old 08-04-2010 | 01:54 PM
  #8393
nmt6789's Avatar
Hey guys how different is the 8ight 1.0 buggy and truggy from the 2.0?
nmt6789 is offline
Old 08-04-2010 | 01:59 PM
  #8394
honestly the 2.0 is better cause they made the changes for a reason!...but i personally have run both and have tried lots of different setups with both cause my buddy has a 2.0 and i have a 1.0 and he knows nothing so i pretty much have to hold his hand and show him what to do!...anyways back on the subjectthe 1.0 can be dialed! and you can smoke people with thousands into their 2.0 it only depends on the driver and how the truck or buggy is setup!
Old 08-04-2010 | 02:47 PM
  #8395
OK,how much travel do you have on the brakes?...do you set them up so you only have to pull a little,like 30% on the EPA? or alot of travel with like 75% on the EPA?
Old 08-04-2010 | 02:48 PM
  #8396
You should always run full rebound with blue groove being the rare exception ... in my opinion.
rc23 is offline
Old 08-04-2010 | 03:11 PM
  #8397
Run more rebound when the track is bumpy or loose. Less rebound when on high traction and smooth tracks. I usually run 50% front and rear or 75% front and 50% rear on the truggy.
As for 1.0 vs. 2.0, the 2.0's do everything better. They're just better cars. They drive better and are more durable.
Old 08-04-2010 | 04:27 PM
  #8398
Hate2Looz's Avatar
I'm loving them on the truggy. They really do make the shocks more consistent. They're recommended for both cars.
Air pressure behind the bladder changes as the air heats up. This makes rebound change and in turn ride height changes as well. Losi cars are very sensitive to ride height changes. When the shocks heat up in a long race without the vented caps, the ride height changes during the race. This will change the way the car drives from the beginning of the race compared to the end of the race. In other words the car isn't as consistent as it is with the vented cap and foam compensator. The whole goal of the vented setup is to provide more consistent handling. Not necessarily better handling, but more consistent handling, which to me is a huge win.
I tell ya what, like I said earlier, I couldn't believe the difference in my ride height on my truggy. The buggy seems to stay pretty consistant, for the most part, but I'm sure it would do quite well with the mod, as well. And yes, the Losi car is VERY sensitive to ride height changes. That was the hardest thing for me to get use to when I started running one.
I noticed a huge difference just between 8 am at the track and just before the first qualifier of the day at 11 am.
Hate2Looz is offline
Old 08-04-2010 | 05:44 PM
  #8399
bigjayjay1's Avatar
Have you guys watched the drake Losi video he shows how to build shocks with their new compensator foams he made it look so easy. Man when I rebuild it takes time maybe I'm going it wrong but to match them identical perfectly i normal have sucked down 4-5 beers for the set.
bigjayjay1 is offline
Old 08-04-2010 | 05:45 PM
  #8400
offroad racer's Avatar
I can usually set the rebound in 10 minutes or less for a set of four shocks, but im not running the compensator foams
offroad racer is offline
