8T 2.0
#8357
Thanks very much for posting up the pictures. I just noted that these were for the aluminium 12 deg spindles. Would this mod with these measurements still work with the standard plastic steering setup or would it be too weak???
Thanks Again????
Thanks Again????
#8358
#8359
#8360
#8361
My truck still drove good with them but I lost alot of steeering, I just wasn't sure if everybodys was the same way or just mine. Seems like losi needs to redesign the spindles so you don't have to grind on them just to get the stock steering throw back
#8362
I couldnt believe the difference by the A-main the kits was super dialed using 95 percent of your setup loving the feel very predictable.
#8363
#8364
Yeah it is really predictably and easy to drive, while still being very fast. I've also since switched to 35wt oil in the rear. Also gone to the EU vented shock caps with the foam compensators cut in half and chamfered(edges rounded off) on the bladder side. 1/2 rebound front and rear. Loving it even more now.
#8365
#8368
Jammin I'm on my phone or k would look.on ur set up what's. N the rear ,I'm runnin 30 and I run 40 up front,I tried 35 and 37.5 and didn't like it unless the track was loomy and blown out then I went to 37.5
#8369
