Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 01-17-2013, 04:44 PM
  #13036
Afun's Avatar
Trader Rating: 19 (95%+)
[QUOTE=stwallac2007;11690989]
Originally Posted by Afun
So these are small enough where you could fit locknuts, no modification needed... I rather Kyosho parts on my Kyosho
Afun is offline
Old 01-17-2013, 04:54 PM
  #13037
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Red loctite and a Lil superglue around the top and they never move
GMS_Racing is offline
Old 01-17-2013, 05:23 PM
  #13038
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by THE PHILLY JYNX
I'm looking for worn out sets of kyosho break pads. if anyone has sets laying around they don't need shoot me a PM. I want to do a little R and D and need used pads...
likkkkke old old or what?
i have tons of parts , the thing is that kyosho parts (brakes) take fooooorrrrever to wear out
soo i have been up to my iballs in kyosho lately , rebuilding cars that i am selling to friends and new builds for myself
i must say does it get any better than Kyosho?
as far as the 91mm axles , how in the F--K r u guys popping these out?
they have the perfect amount of plunge and do not come out of the outdrive during uptravel or downtravel , interesting fosho
i know i am suppose to be building engines but i gotta get my stuff ready to race sometime guys
houston is offline
Old 01-17-2013, 05:32 PM
  #13039
[QUOTE=Afun;11691074]
They're from the Kyosho 777 and yes they work with no modification.
stwallac2007 is offline
Old 01-17-2013, 05:49 PM
  #13040
THE PHILLY JYNX's Avatar
like.... like.... lol. Used and no longer on your veh.they dont need any brake material on them.
THE PHILLY JYNX is offline
Old 01-17-2013, 09:03 PM
  #13041
Originally Posted by Ei8ht
I just bought a 10 hole tower for my buggy which has an 8 hole tower. Before I installed it I lined them up against each other and put bolts through the upper shock mounting holes to keep them aligned. Sure enough all 8 holes on both towers line up exactly and the 10 hole tower has an extra two holes directly below the 8. Hope that helps.
Exactly the info I was looking for!
My ST-RR EVO is offline
Old 01-18-2013, 01:50 PM
  #13042
MCSEDanny's Avatar
Sitting at McDonld's near Winner's Circle waiting for UPS with my TKI3 so I can get home and start building.
MCSEDanny is offline
Old 01-18-2013, 03:09 PM
  #13043
Winner's Circle's Avatar
I know you will love the car. Let me know if there is anything else you need.
Lee
Winner's Circle is offline
Old 01-18-2013, 03:46 PM
  #13044
enjoy cant wait to get mine in a month or two
dooug1960 is offline
Old 01-19-2013, 08:50 AM
  #13045
houston's Avatar
that is some funny azz chit!
you will love this car!
houston is offline
Old 01-19-2013, 09:15 AM
  #13046
Foosmatrix's Avatar
Is the tki2 WC front shock tower the same as the TKI3 unit ? Or is it thinner ?
Foosmatrix is offline
  #13047
houston's Avatar
wow , I have about 10 sets of those, the old mounts r taller though
if you can find the old mp9 mounts tki2 or later , you will be dialed
foos - pretty sure that the WC tower is what is on the current production model tki3 yes
hope this helps
houston is offline
Old 01-19-2013, 10:25 AM
  #13048
nacho_gas's Avatar
Cody King's Orion future in doubt?
http://buggysrc.blogspot.com.es/2013...n-en-2013.html
nacho_gas is offline
Old 01-19-2013, 10:27 AM
  #13049
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Just less material machined off in the tki3 tower. They use different fasteners as well (countersunk main bolts vs. button head).
SEF is offline
Old 01-19-2013, 10:39 AM
  #13050
houston's Avatar
the standard tki2 is different yes but the tki2 wc is the same
houston is offline
