Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 03-18-2013, 02:22 PM
  #13786
Also, I'm having problems setting up the brakes of my MP9 when I brake, there's not enough to stop the car but when I adjust the brake pads together, on neutral the car does not free move. Please help!
george919 is offline
Old 03-18-2013, 03:07 PM
  #13787
Trader Rating: 128 (100%+)
Try adjusting the knurled collers on the linkage by threading them more into the servo arm for fine tuning. Hope this helps
Neesh is offline
  #13788
Charles Godwin's Avatar
You need to adjust your brake end points on your radio if you're not getting enough overall brake. Set pads about 3 quarters of a turn looser than what the pads are then reset linkages and go from there with the radio.
Charles Godwin is offline
Old 03-18-2013, 03:32 PM
  #13789
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by likeaboss
According to this chart, there should be white between grey and lt blue. Why aren't you suggesting white, or why isn't anyone using this spring rate?
Short Length 70mm Shock Spring Specifications:
Softer
IF350-814: Green - 8 turns/1.4 wire (3.68lb-in / 659.38 n/m)
IF350-7514: Orange - 7.5 turns/1.4 wire (4.02lb-in / 719 n/m)
IF350-714: Light Blue - 7 turns/1.4 wire (4.42lb-in / 6.09 n/m)
IF350-1016: White - 10 turns/1.6 wire (4.62lb-in / 820 n/m)
IF350-6514: Gray - 6.5 Turns/1.4 wire (4.91lb-in / 879.17 n/m)
IF350-916: Purple - 9 turns/1.6 wire (5.28lb-in / 937.39 n/m)
IF350-816: Light Green - 8 turns/1.6 wire (6.16lb-in / 1093.62 n/m)
IF350-716: Blue - 7 turns/1.6 wire (7.40lb-in / 1312.35 n/m)
Harder
(Taken from A-Main's site)
probably due to the number of turns.. that changes the way the spring feels
eper is offline
Old 03-18-2013, 03:41 PM
  #13790
likeaboss's Avatar
And that is what dictates the spring rate. My question is if lt blues are the holy grail for the majority of tracks, then going up or down a few increments would allow for needed adjustment. But why grey's and never whites?
likeaboss is offline
Old 03-18-2013, 03:46 PM
  #13791
Thanks Neesh and everyone else who helped. The linkage was not threaded into the servo arm correctly, now it correctly threaded, it brakes perfectly! Another question for you guys. What are some of the best upgrades I could do on my original MP9 to turn it into a TKi3?
Old 03-18-2013, 03:52 PM
  #13792
I think its because most of the drivers prefer the 1.4mm springs over the 1.6mm
RePeTe is offline
Old 03-18-2013, 04:25 PM
  #13793
Afun's Avatar
Trader Rating: 19 (95%+)
I am looking to buy the aluminum wing stay mount Kanai created. Has it been released?
Afun is offline
Old 03-18-2013, 06:08 PM
  #13794
McD44's Avatar
Trader Rating: 16 (100%+)
That's my thought as well. Perhaps the thicker gauge springs are more progressive??
McD44 is offline
Old 03-18-2013, 06:37 PM
  #13795
So I did a 12hr stint yesterday and now finally have my kit together. One thing that is bothering me though is a loud clicking from the rear outdrive on the center diff. I don't know if the dogbone is just slightly rubbing the brake disk as it moves back and forth (since they are slightly off center) or something causing it to click. It was made louder too because my engine block was just so slightly touching the shaft. I removed the engine and ground it a bit and while it was out tried to see what was going on. If I put slight pressure on the shaft with my finger and spun the wheels I could hear it and feel it click.
The drive train is super free and free wheels no problem when I spin the wheels.
I don't think it's anything to worry about but has anyone had this problem?
JJ
JJRC is offline
Old 03-18-2013, 06:51 PM
  #13796
bucket2772's Avatar
[QUOTE=Pete Martinez;11940976]
Originally Posted by killabud
Did up a practice body and tried this E6000 stuff someone on here mentioned. Pretty sure this will last me all season for practice now.
[/QUOTE where did u buy it. thanks
Has anyone ever though about using Flexseal?? I was reading in another forum where a few people have used it and it seems more reliable and less messy than shoo goo and mesh
bucket2772 is offline
Old 03-18-2013, 08:25 PM
  #13797
ON A MISSION's Avatar
Trader Rating: 34 (100%+)
Anybody have a part number for the rear hub spacers without the plastic hub IF422b ? Thanks
ON A MISSION is offline
Old 03-18-2013, 09:12 PM
  #13798
Ifw414-01
Dcracing2 is offline
Old 03-18-2013, 09:21 PM
  #13799
Thanks but I'm looking for the wheelbase spacers 5ml 2ml 1ml . Seperarte from the plastic hub
Old 03-18-2013, 10:38 PM
  #13800
Guest
They will be here shortly, cause I am wanting one too.
kyoshoracer77 is offline
