Inferno MP9 thread
#9706
Guy's, Off topic, but did Odonell stop making glow plug's? Nobody has them anymore. And who uses the aluminum front c hubs? Is there a big diffrence?
#9707
OD I dont no but the allum hubs a few grams heavy than plastic and they are cool looking
#9708
Thank's Coach. Hey is Reggie still driving a Kyosho?
#9710
#9711
He better or Im goin to kick his knees when I see him
#9712
Lazy
Lol what do you mean lazy for my aggressive style?
#9714
The allum. c hubs give it a more positive feel,,,,
The chassis,,,,,,,, well whoever dont think there is an issue is nuts !! Yep i said nuts I ran the OS 19 with a very small mark from the clutch bell and then switched to Nova and have been through 4 front bearings, a bent crank and a cracked block. I think that counts as a problem But the problem is GONE !!! I started with drilling a hole (1/2in) and then i bought a BCE chassis wich came with a hole already in the chassis. I went through one more front bearing and then removed ALL the material under the bell and WALLA problem fixed Truely a bad ass car,,,, just a few tweaks, just like all cars out there.
Scott
Scott
#9715
Amen
Scott. Totally agree with you. If you drive on a gentle track with small jumps you will only see marks in the chassis. If you drive on a track like Fear Farm where they had the Nitro Challenge clutch bells will blow up. Dremmel out under the clutch bell and put a brace in and the problems will go away.
Side note: Tebo was using a TKI 1 chassis at the Nitro Challenge as the TKI 2 had too much flex for the big jumps and he drives soooooo smooth. Think about the average driver that has 10 x more crashes and 10 x worse crashes. Fantastic car but the flex at the clutch bell needs addressing!!!!!
#9716
So you guys think removing all the material under the bell is the best option? I saw that the new BCE chassis comes like this. If I remove all the material, will I be ok running the stock engine mount instead of a kings head extended?
Also, with the large opening under the clutch bell, anyone worried about flameouts caused by dirt getting jammed into that area?
#9717
Scott
#9718
Flameouts
#9719
Are there any part or parts I should buy with the new tki3 kit? I have the kit in my shopping cart on amain??
#9720
The stright shock pistons are a must. I dont know if thats what comes with the 3 or not. It's the 1.3x8 hole. KYOIF347-138
