Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-27-2012, 06:40 PM
  #9721
Trader Rating: 6 (88%+)
Default ???
Ok thanks a lot will the setup that cones with the car be good or should I start somewhere else?
Drip is offline
Old 04-27-2012, 07:17 PM
  #9722
drstrangelove's Avatar
They are close i.e. the manual and those pro setup. Some people will tell you it's ok to use the setup recommended by the manual, some will tell you to consider the pros setup as a start while some will tell you to decide what's best since no one know your driving style and track.
One thing I've learned, don't worry about which setup to go with yet but if you must you can find it here http://www.infernosonly.com/Download...heets_s/24.htm
I'm talking through experience, if your driving skill is bad, no car or setup can improvise it (but Kyosho might be more forgiving ). Guys here advise me to go slow and like miracle I'm starting to see the beauty of this car and for some strange reason I can even feel the momentum when I'm doing the jump, feel like you are jumping with the buggy feels good!
drstrangelove is offline
Old 04-27-2012, 07:22 PM
  #9723
Just realize you are driving HB. My buddy who is driving HB Hara Edition will be switching to TKI3 soon (When the stock arrive). He tried another buddy TKI2 and love it but still not decided yet but after seeing I'm using that, and try them, he's getting. He got 2 sets of HB buggy and willing to let it go just to get 1 set of TKI3. That says a lot about this buggy.
Old 04-27-2012, 09:14 PM
  #9724
305M3's Avatar
Trader Rating: 43 (100%+)
No more fitting RC8 bulldog bodies, MP9 finally has their own.
Unless this has been out for a while and I'll go back under my the rock I've been hiding under.
305M3 is offline
Old 04-27-2012, 09:36 PM
  #9725
freefallmarine's Avatar
There was one from a company in Europe. dont know anyone who used it though. This is going to be good. Another tuning option!
freefallmarine is offline
Old 04-27-2012, 09:42 PM
  #9726
305M3's Avatar
I think you are talking about Bitty Design. I have one at the paint guy, CBD, now. Can't wait to see the magic he works.
305M3 is offline
Old 04-27-2012, 11:23 PM
  #9727
wheelman17's Avatar
Originally Posted by shinnbad12
The allum. c hubs give it a more positive feel,,,,
The chassis,,,,,,,, well whoever dont think there is an issue is nuts !! Yep i said nuts I ran the OS 19 with a very small mark from the clutch bell and then switched to Nova and have been through 4 front bearings, a bent crank and a cracked block. I think that counts as a problem But the problem is GONE !!! I started with drilling a hole (1/2in) and then i bought a BCE chassis wich came with a hole already in the chassis. I went through one more front bearing and then removed ALL the material under the bell and WALLA problem fixed Truely a bad ass car,,,, just a few tweaks, just like all cars out there.
Scott
I've been running the new mp9 BCE chassis that has the relief hole and there is not a mark on it. I've been using the alu rear chassis brace. Still have tons of rear traction and also helps rotate the car a little faster. The BCE chassis is awesome moves everything a tad bit closer to center, stiffer than stock has the relief hole already in it and really reacts a little sharper than stock. Made my lazy stable setup feel faster without losing stability
wheelman17 is offline
Old 04-28-2012, 12:54 AM
  #9728
Oh wow, years of development by Kanai and Kyosho and all it takes is BCE chassis to make the buggy faster and more stable. Interesting.
Old 04-28-2012, 12:55 AM
  #9729
Yap, Bitty Design. I though I saw the Bulldog body on AbsoluteHobbyz some time back but I might be wrong. Nice, should give that a try.
Old 04-28-2012, 01:57 AM
  #9730
Originally Posted by talbotbid011
I was reading posts earlier in this thread where people were having to use Agama motormounts mated to MP7.5 motor mounts (upper) and drill half inch holes in the chassis etc. scary stuff really.
The it was sugested to go from 13-46 to 14-48 because the gears line up better...
Just wanted to know if this was a recent concern with K-Cars or were these issues isolated to a certain batch of kits?
Never heard about any issues like this in Europe and i donīt see any reason why change the gearing and how that should make the gears line up better.
PiRo is offline
Old 04-28-2012, 02:43 AM
  #9731
chiefN420's Avatar
+1
chiefN420 is offline
Old 04-28-2012, 03:16 AM
  #9732
Default ???
What did your friend say the biggest difference he could feel from the hb car and the kyosho?
Drip is offline
Old 04-28-2012, 05:24 AM
  #9733
shinnbad12's Avatar
PAUSE your keyboard and take some notes !!! Statements like this one make you sound like a fan boy,, The Kyosho that qualified second at Silver State was sporting the BCE chasis. His truggy and E buggy were also wearing BCE chassis and all three in the A main ??? this isnt luck. The product has been proven to work, its just the customer service that need some refinment.
That being said,,,, I also believe that Kanai has been leading the industry for years and with out a doubt has every other car company scratching their heads I to love the Mp9 and have personally switched at least 6 drivers to Kyosho. I do not carry the BCE flag but when something works ,,,well,,,,it just works. Not preaching just saying,,,,.
Scott
shinnbad12 is offline
Old 04-28-2012, 05:43 AM
  #9734
What he say is he feels the car go where you want it to go, something like when it commit to the turn, it just turn, something about planted... I can't quite recall but something close.
Old 04-28-2012, 05:47 AM
  #9735
Noted bro sorry, can't help it...
Scott
