Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-22-2012, 09:59 AM
  #11206
CoryD's Avatar
If anyone wants mad steering my friend ran the al. c-hubs up front with 7-5-4 diff oils -- car was an animal! It seems that the al. c-hubs made the difference cause my car had the same diff oil package and now where near as much steering.
Just an FYI for the group.
Later,
CoryD is offline
Old 08-22-2012, 11:36 AM
  #11207
Coach Townsend's Avatar
Later,
Your not the first person that said that.I might have to get a pair
Coach Townsend is offline
Old 08-22-2012, 11:56 AM
  #11208
Later,
do you have part number i cant find them at amain
nevermind i think i found them You are talking about these right? http://www.amainhobbies.com/product_...ront-C-Hub-Set
evolution03 is offline
Old 08-22-2012, 12:20 PM
  #11209
CoryD's Avatar
KYOIFW412
Regards,
CoryD is offline
Old 08-22-2012, 12:47 PM
  #11210
305M3's Avatar
Trader Rating: 43 (100%+)
Later,
+ a lot...
I found out about the increased steering this past weekend at Wicked. I ran the same setup for all 4 quals and the night before the main decided to install the aluminum c-hubs. I didn't have a chance to practice w/ them prior to the main. The increased steering screwed up all the turn points and how to drive the track (ie., where I would turn/brake/accelerate).
Oh well, lesson learned for next time.
305M3 is offline
Old 08-22-2012, 01:21 PM
  #11211
Gixer Jay's Avatar
Later,
+1 Just put a set on my buggy! Also, makes the front-end a lot tighter.
Gixer Jay is offline
Old 08-22-2012, 07:12 PM
  #11212
jmtrogers's Avatar
Trader Rating: 22 (100%+)
FYI: They wear really fast
jmtrogers is offline
Old 08-22-2012, 07:49 PM
  #11213
So how much time are on those ? Are they still useable ?
Old 08-22-2012, 10:26 PM
  #11214
AZRC4Me's Avatar
Mine look like that, been running them this whole season. When they start to feel loose between the arm, add a spare shim that you use to space the clutch shoes off the flywheel - put the pin into the arm, then add the shim, then put the c-hub in, then push the pin through. If the knuckle is loose up and down in the hub, just add a shim or two where needed. Being loose isn't a bad thing, you don't want things binding, but a shim or two here or there helps. Also, it helps to replace the caster bushings when needed, and add a dab of tire glue to the c-hub before putting the caster bushing in.
AZRC4Me is offline
Old 08-23-2012, 12:30 PM
  #11215
Imcaracer20's Avatar
Which caster bushing are you running?
Imcaracer20 is offline
Old 08-23-2012, 01:05 PM
  #11216
AZRC4Me's Avatar
Depends on the track conditions but the middle hole (0) is my default.
AZRC4Me is offline
Old 08-23-2012, 01:41 PM
  #11217
Dyno-Dylan's Avatar
Trader Rating: 36 (100%+)
Talking
Is there a part number for just the caster bushings? Also check your pms please
Dyno-Dylan is offline
Old 08-23-2012, 02:12 PM
  #11218
AZRC4Me's Avatar
IF421-01
Done, response sent.
AZRC4Me is offline
Old 08-23-2012, 02:14 PM
  #11219
Dyno-Dylan's Avatar
Thanks again for the help man
Old 08-24-2012, 08:17 AM
  #11220
Happy Meal's Avatar
IF421-01
Hey, Sean
Do you know of another place to get this at a low price? A-main doesent seem to have it....only available with the c-hub....
Thanks!
Happy Meal is offline
