Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-28-2012, 05:47 AM
  #9736
Stardust's Avatar
Exactly! The BCE chassis is an option that some feel benefit the car, is it a needed option? No Sir.. The stock chassis is fine and if your concerned with the clutch bell hitting the chassis take a dermal to allow clearance under the bell..took me 2 minutes to fix. Anyways the car Rocks have fun!
Stardust is offline
Old 04-28-2012, 06:57 AM
  #9737
wheelman17's Avatar
Originally Posted by shinnbad12
PAUSE your keyboard and take some notes !!! Statements like this one make you sound like a fan boy,, The Kyosho that qualified second at Silver State was sporting the BCE chasis. His truggy and E buggy were also wearing BCE chassis and all three in the A main ??? this isnt luck. The product has been proven to work, its just the customer service that need some refinment.
That being said,,,, I also believe that Kanai has been leading the industry for years and with out a doubt has every other car company scratching their heads I to love the Mp9 and have personally switched at least 6 drivers to Kyosho. I do not carry the BCE flag but when something works ,,,well,,,,it just works. Not preaching just saying,,,,.
Scott
+1
wheelman17 is offline
Old 04-28-2012, 09:32 AM
  #9738
drstrangelove's Avatar
Sorry bro, not trying to make fun of your post
Originally Posted by wheelman17
+1
drstrangelove is offline
Old 04-28-2012, 10:28 AM
  #9739
wheelman17's Avatar
Originally Posted by drstrangelove
Sorry bro, not trying to make fun on your post
No problem, just letting people know what the BCE chassis feels like to me.
Not that the stock chassis has problems,because it doesn't. I know that BCE has been working on this chassis with the help of some of their pro drivers for a long time. They made some small changes that made a perfect platform even better IMO.
Old 04-28-2012, 07:17 PM
  #9740
Pete Martinez's Avatar
Trader Rating: 17 (100%+)
question guys how can i take away some of the twitchy in the steering.
Pete Martinez is offline
Old 04-28-2012, 07:34 PM
  #9741
Have you tried adjusting your steering EPA?
Old 04-28-2012, 07:49 PM
  #9742
Trader Rating: 27 (100%+)
Hey Pete, I didn't get a chance to look at your servos today but if they are high speed servos you should turn down the servo speed on your radio or try running some expo to slow down the initial reaction. I've known many guys to buy servos, engines, etc etc.. base on specs not realizing the effects it may have on drivability. Servos is one of those things, yours just might be too fast, giving you the elusion that your cars setup is twitchy. I believe that any servo under .10 sec in buggy is gonna be a handful, especially driving a car as responsive as the 9.
Just a thought before you go chasing setup changes...
Johnieblaze is offline
Old 04-28-2012, 09:02 PM
  #9743
Broke my first front lower arm today. How cool can that be! Straight, high speed and small hump on the side... bad combination, buggy fly hit tree and I go NOOOO SHIT... So so cool! This thing is build like a rock. I thought it would be more but just the lower arm, the rest all still going strong!
Old 04-28-2012, 09:06 PM
  #9744
Stardust's Avatar
Ouch! looks like you chipped off a piece of your outdrive?
Stardust is offline
Old 04-28-2012, 09:33 PM
  #9745
Outdrive all fine, it just pop out when the arm when lose. I was more worried about the shock due to the angle of the arm when i first carry it, thought I might bend it but all ok except the lower arm, so that's cool.
Old 04-29-2012, 12:56 AM
  #9746
Trader Rating: 16 (100%+)
Oh wow, years of development by Kanai and Kyosho and all it takes is BCE chassis to make the buggy faster and more stable. Interesting.
Listen to what you're saying, doc. Not sure why this would be such a revelation or hard to believe. It's very easy to make any car more stable, it's far more difficult to make a car steer faster and still be nice and progressive, stable and controllable. What exactly would be the point of releasing a chassis for any car if there wasn't going to be some sort of change/improvement? And you should know as well as anyone, everything here is all 100% biased personal opinions. We're all biased because we work hard for the money that pays for our toys. No one is saying this is 100% true and undoubted facts, which will do the exact same thing for every single driver under every single condition, just 1 guy saying how it affected his drive. Stable essentially equals understeer because if it were steering more/sharper, that wouldn't be considered stable.
Just my 2cents.
Where is it twitchy Pete - in a straight line, on corner entry, etc? If it's in a straight line which you're talking about, what toe-in are you running? I had the exact same problem and I went from 3o toe-out to 0.5-1.0o toe-out and instantly the twitchy, unstable feeling was gone. Of course, this also affected corner entry, but I had no problems giving up some off-power steering as there was too much for me when running 3o toe-out and made the car over-rotate for my driving style.
If you're running 2+degrees front toe-out, try reducing the toe-out and that should definitely help with removing some of the twitchy feeling you're experiencing.
aaron125 is offline
Old 04-29-2012, 04:15 AM
  #9747
So, 500 odd stupid posts in a matter of weeks = expert no it all douche bag!
And in case you didn't know, no one gives a crap you broke a bloody arm.......
ratjayfala is offline
Old 04-29-2012, 04:21 AM
  #9748
Now, now boys play nice. There's no need for any of that.
aaron125 is offline
Old 04-29-2012, 04:25 AM
  #9749
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
Wow - dude - moments goooooone!!
Hey - you have half the posts he has...
Leave it - the two people involved played nice and mature - perhaps you could learn from that rather than name calling etc...
Cheers
Darryn
RETRO R/C is offline
Old 04-29-2012, 04:31 AM
  #9750
Cheers
Darryn
Who gives a crap how many posts I have. My point was this moron is trying to pass himself of as some sort of expert after posting a few stupid comments. I'm not the one making sweeping claims about a products validity.
See you down at Narrubundah soon
