Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 04-22-2012, 11:03 PM
  #9541
drstrangelove's Avatar
LOL you guys are horrible, laughing at all these brands... but I guess it's true. When I first saw my friend XB9 I was like wow, they had the battery on the front too just like Kyosho and than I realized... oh they copy Kyosho....
Originally Posted by AZRC4Me
+1 - nobody gets fast by wrenching. but if you've got another car, then that's cool. but the more hours you spend with the transmitter in your hand driving, the better.
hahahaha, kyosho clones lmao.
again, lmao, classic.
drstrangelove is offline
Old 04-23-2012, 04:54 AM
  #9542
shinnbad12's Avatar
Originally Posted by drstrangelove
so am I.
The question i answered was where to get front and rear blue springs,,,,,,,,, nothing about the TKI3 ??? Whats so confusing ?
Scott
shinnbad12 is offline
Old 04-23-2012, 05:10 AM
  #9543
Scott
I think the confusion started at #9517. Scott if you click on the link that Aaron provided
Hotseat is offline
Old 04-23-2012, 05:23 AM
  #9544
shinnbad12's Avatar
Yes you are right,, all this hype about the III IMO it will not change anything in the performance part of the car. I feel the changes are good as all the changes Kyosho has made to the car in the past and im sure i will buy the new stuff as i run out of spares but nothing to get excited about.
Scott
Old 04-23-2012, 05:47 AM
  #9545
Hey guys,
What have you found to be the best option clutch setup for the K car.
I've had a few drama's with the kyosho clutch, i.e hanging up shoes and broken springs afte an hour of running with like 6 x 10 minute qualifiers.. so it's time I looked for another option that sits well with the clutch bell. Looking forward to hearing replies, even replies with good life from kyosho ones as to see if I'm doing something wrong.
Soapy is offline
Old 04-23-2012, 05:52 AM
  #9546
OK guys does anyone have the part number for the mp777 unis or some other cvd or drive shafts to fit the mp9. I am getting really tired of them breaking in this car. 2 weeks in a row i have broke the cvds. Out front last time and this time running second. Car is great, but if keeping breaking what good is it if i cant finsh a race.
losi8ight2.0 is offline
Old 04-23-2012, 05:58 AM
  #9547
hefe's Avatar
ok...so i have found some old K swingshafts that should be pretty indestructible.
a friend at the track had a box of old kyhosho parts and these axles were the exact size needed for the mp9...but they are 4.5mm thick! quite a bit heavier too...but i have a feeling they should hold up to some abuse.
still unsure of what vehicle they came from (i had a mp777 sp2 long time ago and dont remember having such massive axles..)
pic shows these pieces compared to a normal mp9 swing shaft (top)
(still havent broken an mp9 shaft yet...but these are just in case)
hefe is offline
Old 04-23-2012, 06:01 AM
  #9548
Trader Rating: 16 (100%+)
Originally Posted by Soapy
Hey guys,
Never had a single issue ever with the Kyosho clutch, I reckon it's just about indestructable. So reliable and easy to build, are you building yours exactly as per the steps in the instruction manual?
And as Mr King is always pointing out, the K clutch in stock form did win the WC without any issues and Tebo and King still run it. It might not be as easily adjustable as some other brands on the market but it is definitely reliable AFAIK.
If the shoes are hanging up and the springs breaking, perhaps you might not be shimming the clutch bell correctly. I very often run old/previously used springs for practice and never had a problem with them breaking.
aaron125 is offline
Old 04-23-2012, 06:06 AM
  #9549
Trader Rating: 33 (100%+)
how are you breaking shafts.. that dont make sense.. i have the original TKI, and the original shafts.. never broken..
what shaft are you breaking.. where is it breaking.. hard landing.. just gassin on it? seriously.. something must be wrong to break them like that..
dgrobe2112 is offline
  #9550
The 777 SP2 definitely had very similar unis to those ones with the funny ring in the middle. And I'm pretty sure I remember from back in the day that those all silver centre unis are also from one of the 777 variations.
aaron125 is offline
Old 04-23-2012, 06:10 AM
  #9551
hefe's Avatar
i remember the little rings on my old 777...maybe i just forgot how chubby they were
hefe is offline
Old 04-23-2012, 06:14 AM
  #9552
Snapping the the ball off at the outdrive. I have simmed right and everything set right.
Old 04-23-2012, 06:20 AM
  #9553
Ok got my truggy and buggy bodies all cut out. As usual, thanks to Mr Larry King... err I mean Larry from KustomGraphics.
Old 04-23-2012, 06:21 AM
  #9554
ben73's Avatar
Trader Rating: 40 (100%+)
Hey guys,
Kev
I have been using the ascendancy products for the past 12 months. No issues at all. awesome longevity from the shoes and easy to change springs etc..
Works on the K car no issue. I use their clutch and vented clutch bell
Well dope on the weekend, was great racing in the main with you mate
ben73 is offline
Old 04-23-2012, 06:27 AM
  #9555
Hmm... interesting, one option that I can think off is BUKU clutch. But you need to get the 32mm one and use a vented clutch bell, the stock clutch bell won't work.
http://www.bukupower.com/Clutch.aspx
Hey guys,
