Inferno MP9 thread
#8041
#8043
The older you get, the more you actually enjoy it, as it is not about winning, but be the best you can be and accepting there will always be someone better and faster than you.
Long live the MP9
MP9 TKI
MP9 SE
MP9e
MP9 TKI2
MP9e SE
MP9 TKI2 WC
I foresee one more MP9 revision before a complete new chassis release in 2014
Long live the MP9
MP9 TKI
MP9 SE
MP9e
MP9 TKI2
MP9e SE
MP9 TKI2 WC
#8044
Long live the MP9
MP9 TKI
MP9 SE
MP9e
MP9 TKI2
MP9e SE
MP9 TKI2 WC
Long live the MP9
MP9 TKI
MP9 SE
MP9e
MP9 TKI2
MP9e SE
MP9 TKI2 WC
About the new model for the WC, we will see whether it will be a revision or a completely new model. More important? Another title
#8045
Quick question!
I am running the 91mm swing shafts all around, on the front i have them shimmed on the inside (one side has a shim on the outside as well). When i have the car at full compression off the ground i can get the pin on the swing shaft very close to popping out of the outdrive, is this normal? I have to really flex the arms to make this happen but its enough to make me worry a little.
#8049
Anyone have any idea if any other brand's diff gears would fit/be the same size and useable inside the Kyosho diff cases? I've seen many machined or hardened steel gears that look to be pretty much identical to our MP9 diff gears but that's only from pics, not from looking at the actual gears themselves. Would love to know if any other brand gears will fit coz I hate the absolute rubbish gears we have to make do with, cast from pot metal or whatever happens to be the cheapest, crappiest steel Kyosho can buy in bulk.
This was asked about some time ago, dunno if it was ever answered, but here's the alloy servo arm that will work for the throttle/brake on the MP9, as it has a 'stepped' arm, as in one side higher than the other, just as per the stock Kyosho part. No idea why anyone would need it, but here it is all the same.
http://www.amainhobbies.com/product_...taba-Savox-ACE
#8050
http://www.hudy.net/xhudy/products/p...9&kategoria=67
#8051
Hello Guys,
i am using Kyosho Oils for my beloved MP9 but i think the bottle is a little overpriced specially the shocks one since the bottle is so small and you basically can only do 1 maintenance per bottle. Do you think the quality is worth the price or can you tell me what oil brand do you use ? i noticed from the settings that pitpop does not uses K oils.
Thanks and Cheers,
C2K
Thanks and Cheers,
C2K
#8054
What rebound is everyone setting their shocks up with??
