Mugen MBX6
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I just order my first 6r u.s spec. but I like the Kyosho springs. Will it fit the Mugens for the front and rear using stock towers.
Steven
Steven
Yes sir, most of mugens are 86 rear and 75 front. I used orange big bore 84mm rears before on my car. Worked good I just didn't keep them on. Fronts I never tried but I have seen people use them. The 70mm fronts I think IMO may be a little to short but u can always crank down collets for your ride heigth.
more forgiving and more turning and more traction than losi, if setup properly. your turning issues could of been to not setting end points correctly, a LOT of people set mugens end points wrong, if you set the end points on the box you have about 30% less steering right there, you have to set them with arms level/on the ground at ride height.
Best tip I've had for this car by far..
Cheers mate
I agree. It's one of those things we do during setup and before raceday, but forget to mention. If you take your time setting up the endpoints and the alignment of the servo saver and tie rods you will have such an easier time racing. It's not easy to put into words all the little things.
Is there any difference between the 6 and the 6r in size for this body ?
Is their anyone on the other side of the pond that can get Reckward parts? I'm looking for part numbers TU8723 and TU8722
Send me a PM if you can help.
Ive just rung the RMV importer for the UK and he wont have stock for 3-4 weeks, and i think that will be quick for them.
The other place to get them is from RMV Deutschland. Ive posted some links below .
'tu8723' http://www.rmv-deutschland.de/catalo...sult/?q=tu8723
tu8722 http://www.rmv-deutschland.de/catalo...sult/?q=tu8722
And there main web site http://www.rmv-deutschland.de/
Hope that helps.
Ross
Hope that helps.
Ross
Hope that helps.
Ross
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
Mugens did work at Revelation this past weekend... Took 1st,2nd,3rd and Dane Jackson won in both truggy and buggy! Good job
sorry for the dumb question but i am trying to understand how to measure the ride height on my mbx6. When you measure from the bottom of the chassi do you then half to go back to the shock collars to make sure they are
even and if so why dont we just measure the distance on the shocks. I am trying to achieve 31mm front and 30mm back. On the factory set sheets it allways shows but i see nobodys uses this method.
hope i made sence and again sorry for the dumb question but any help would be great.
thanks
john
thanks
john
