Like Tree3Likes
Mugen MBX6
Old 02-17-2012, 10:50 AM
  #15526
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
That track looks a lot like US tracks in that is has large jumps, tight and technical, a little blown out, and low to medium traction. Not your usual smooth flowing smaller jump European track. And Battle setup says he is running 23mm (f) and 26mm (r) for ride height. On US tracks, most setups I've seen are between 27mm and 30mm.
Has anyone tried a lower ride height? US tracks just seem too bumpy with large jumps for such a low ride height (I run primarily at Revs).
SEF is offline
Old 02-17-2012, 10:55 AM
  #15527
mjealey's Avatar
I have tried running the 23 and 26 ride height and on some big jumps I bottomed out pretty hard and didn't wamt to go to a lot stiffer springs or oil. I have met in the middle and now run 26f and 29r and see,s to work good for your average tracks.
mjealey is offline
Old 02-17-2012, 11:10 AM
  #15528
The best way to keep from flaming on your pits is to have your driver go wide open right after you shut the lid before setting the car down. It takes a little practice to get the timing right but it has always worked for us.
donrod is offline
Old 02-17-2012, 11:12 AM
  #15529
Harley here is the setup we were running with the BCE 3mm chassis, if you need any more help feel free to ask. Donnie
donrod is offline
Old 02-17-2012, 12:27 PM
  #15530
Trader Rating: 25 (100%+)
Originally Posted by Mr LowDown
Any news on the mbx7 yet?
Mugen doesn't introduce new models/platforms as often as other companies. Roughly one every 4-5 years.
MBX-5 - 2003?
MBX-5 Prospec - 2006
MBX-6 - 2008
MBX-6R - 2011
Based on that trend, I wouldn't expect a MBX-7 until 2013...especially since the 6R was just released a few months ago.
lknracer is offline
Old 02-17-2012, 12:57 PM
  #15531
Mr LowDown's Avatar
Trader Rating: 21 (100%+)
Thanks a lot dude
Mr LowDown is offline
  #15532
morgoth's Avatar
Yep!
morgoth is offline
Old 02-17-2012, 01:03 PM
  #15533
Company Representative
JoeNolasco's Avatar
Originally Posted by TeroRider
Hey guys! What do you think of the idea to run an empty fuel filter(meaning that it is without the filter element itself, rendering it only a container for air) in the pressure line instead of an extra long pressure line? Do you think that the extra space in the filter will be the same as the extra space in a longer fuel line?
Sorry to change the topic all of a sudden, I am just wondering since I had some flame-outs after pit this year.
Regards,
Terry
In practice, get off the stand and have your pit man do a stop while you watch. Is he getting fuel all over your pipe? That will do it every time.
I crack my carb open just a tiny bit and hold it there during all my pit stops (basically, I go to a high idle) and right as my pit man starts to set the car down I go wide open to clear it out. Let go of the trigger as soon as the wheels hit the ground.
JoeNolasco is offline
Old 02-17-2012, 01:05 PM
  #15534
Numburn's Avatar
How so? <- noob
Numburn is offline
Old 02-17-2012, 01:39 PM
  #15535
HH
HH's Avatar
Thank You Donnie!
HH is offline
Old 02-17-2012, 01:51 PM
  #15536
Ok thank you ,juninho
Alentino is offline
Old 02-18-2012, 08:33 AM
  #15537
Trader Rating: 45 (100%+)
Thought Id post some pics of my new 6R!
kaotickc is offline
Old 02-18-2012, 09:04 AM
  #15538
adrictan's Avatar
Wht r u guys using to stick the fuel line holders to the fuel tank?
adrictan is offline
Old 02-18-2012, 09:07 AM
  #15539
I use tire glue...
kaotickc is offline
Old 02-18-2012, 09:30 AM
  #15540
Originally Posted by curacing2
Terry, it might help a bit but the problem is a bit to do with the tank forcing fuel into the carb when filled right to the top and snapping the lid closed...I get a very rich almost flaming for 5 seconds out of the pits with my mbx6 when the motor's a bit low on compression and the idle gap is open a bit wide...doesn't flameout too often though.
with a fresher motor in it doesn't do it, so tuning, compression and the extra bit of pop to burn the extra fuel makes a lot of difference.
What motor and plug are you Terry?
Craig
Thank you!! I am running Ninja JX21 with a P4 Ninja plug. Fuel is 25% with less oil.
The exact problem is that I manage to go through the straight with full throttle but when I lift it for the first corner the engine flames out.
TeroRider is offline
