Team Associated 1/8 scale Truggy Info and Tips
#3076
#3078
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hey guys I just put a new rod, piston, and sleeve in my os speed. I did a brakein and things were good until I got on the track. Now the motor revs real high when the truck is off the ground after a jump. I fatten the low neddle but that didnt fix it. I'm running a #7 restrictor, but i'm going to try a #8 Or #9 restrictor and if that doesnt get it then a different carb. BTW NO LEAKS but I did notice that I had to really prime the hell out of it to start. The fuel just didnt move up to the carb with my finger over the pipe. Has anyone ever had this issue???? ![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
![flaming mad](https://www.rctech.net/forum/classic_images/smilies/angryfire.gif)
:f laming:
#3080
#3082
:f laming:
#3083
#3084
you should lean it on the low end until you have a stable but very high idle.
#3085
I haven't seen it posted but am willing to bet it is probably VERY close to the 2009 Nats winning setup (maybe even identical). Ryan hardly ever changes his truggy setup. It was even the same tires from '09.
#3088
only differences are how much they weight and the color
. Carbon ones are lighter.
The aluminum ones have pre machined holes for the JC punisher body, the carbons require drilling or the adapter that JC sells.
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
#3089
Does anyone know if the proline 8t truggy body, will fit the rc8t? Thank you
#3090
i and others have mounted the punisher without the adapter,.. i did purchase it but didnt use it.. what is its purpose exactly? i need a new body and guess i should use it this time. hey brandon can you please or someone explain bumpsteer? what does adding a washer do,and under what conditions if not all is it beneficial? lastly what size washer and are people only running bumpsteer on buggy or truggy also. thanks
