Team Associated 1/8 scale Truggy Info and Tips
#2926
Shock Oil Set up
Hi Guys,
Any suggestion on shock oil to use for a truggy? I will be running this in a high speed track with 4 feet jumps. I dont know what oil to use so your help is greatly appreciated
#2928
Is that 40w front and rear? some people recommends that the front should be a bit stiffer. I am a bit puzzled. All I know is that my rear shocks are too soft. When you drop the kit at the height of 1ft, the chassis slams to the ground
#2930
I would go with the box set up. So you have a base line to work from. Also a car doesn't drop straight down when jumping.
#2931
The box CE setup has been dailed for me. 35wt front and rear 1.3x6 pistons silver springs.
In the cold I run 30wt but I think its time to go back to 35wt this week.
#2932
I think I will start with the box set up and adjust the shock oils if needed.
#2933
#2934
in case if anyone is interested you can get A Factory Team RC8b and a RC8t CE for a great price on ebay from speed-rc. I got the RC8b for $342 and the RC8T ce for $335. They also have eBuggys. Sweet. They only sell AE stuff from what i can tell. I would have told you guys sooner but i wouldnt want you guys to run up my bill. BRAND NEW IN THE BOX! http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
#2935
shock set up
Hi guys,
I changed the set up of my suspension to stock. How will I know if my shocks are too soft? I tried to drop my kit at at height of 1 foot. The front end of the chassis slams to the ground? Is this normal?
#2937
well, i finally raced yesterday with the rc8t ce and wow it does not handle like a "truggy" at all its like a "buggy rotates like one and steers like one" i cant believe how much "steering throw" it has.
i added about 2 degress of toe out on the front and it does have a tons of steering maybe a bit much but im just going to get used to it for now.
oh yea its very quick add that with a 4 shoe clutch its quick !
its defiely not heavy the specs are wrong lol .
#2938
You don't need to drop it 1ft. Just drop it from 6 or so inches, enough to settle the suspension. Then check the ride height. If you drop the truck from a foot its going to bottom out. If you flat land on the track on a big jump, it will bottom out. Try to land front wheels first (barely) and it'll be smooth and not slam the ground.
#2939
yeah. Maybe I will try this first in the track this weekend. thanks for your help guys
