Team Associated 1/8 scale Truggy Info and Tips
#2567
20 bucks
I'll bet you 20 bucks he has the rear chassis brace in the front.
#2568
I tried 7/7/5 instead of 7/7/7 and it did both. Made it a little twitchy everywhere else, but also made it turn a little harder and decreased push going into and mid corner. The track I run on is loose, so ultimately I didn't like it because it just wasn't stable enough and I was a little inconsistent.
#2569
im, not bad mouthing them just i previous expriences ive own other associated and losis but just in my luck theres something missing or something and its not me that looses it .
there good cars .
#2570
#2571
Take a picture of it. I just got my kit in last wednesday and it was fine. I would like to see a pic of it though.
#2572
here you go .
#2573
#2574
theres only 1 small one missing see in the pic its in front of where the the holes are to bolt on the center diff on to .
#2575
When you put the center diff together there will be a center diff riser that you put on before the center diff mount. The front chassis brace mounts to it in that hole thats in the pic.
#2576
In this hole
#2577
#2579
yeah. Just keep putting it together TC5man and you will see it works. and when the new chassis come it will look the same
#2580
No, unless my manual is different than anyone else's, it shows that the center diff brace/riser goes below the center diff and then the chassis brace connecting to the hole on the front of the center diff brace/riser. That hole is where the screw holds it together.
My chassis is the same one you have. just finish putting it together. you will see.
