Kyosho ST-RR
#1591
seems to me like people are getting to hung up on this outdrive issue,i havn't had any issues with the outdrives on the buggy or truggy
#1592
the truck runs great and super dialed though
cheers
Ali
#1593
There was an issue with the MP9 TKI2 outdrives for a while but that has now been corrected (see the MP9 thread).
I don't think there ever was an issue with the ST-RR outdrives. Just the D8(T) ones are lightweight ánd last longer: they don't chip as easily on the edges.
I have not heard of an update on the ST-RR Evo outdrives.
I have posted this pic a couple pages back aswell.
Some bad chipping going on and this is with fairly new dogbones, the left cups haven't seen a lot of use either. After this initial chipping they last a long time but it does give more play and more wear on the drive train.
#1594
for me, I always ran the lightened D8 outdrives and ring gear in my ST RR....simply because its lightened. I used to use the lightning pinion and grind it a bit shorter for it to fit properly. Lasted alot longer than the kyosho ones. I will run only lightened outdrives on the EVO though.
#1595
Ran my Evo hard yesterday. Everything was great , however I'm going to upgrade to the Kingheadz rear chassi brace. The stock one will eventually pop off due to flex.
#1596
As far as the HB drive parts you hear alot of complaints in the D8T thread about early wear whether its stock or the lightened. I have not had any problems with wear really with a slight bit of chipping on some I still get alot of time on them.
#1597
the Aluminum one will take alot of flex and rear traction!! run the aluminum one if your track is super high bite.
also do the battery mod and move it up front, steering is crazy and jumps even better than before.
here are photos of the battery mod
used 2 plastic wing spacers, drilled the side guards, mount the spacers, drimell a nice piece of carbon fiber, double side sticker to stick a piece of foam under the CF so the pack doesnt move, drill 2 holes on the CF, get 2 screws with sink washers, put your name on it and Voila !!! better than Paul King
cheers
Ali
#1598
Suspended
ST-RR Evo Lipo RX pack?
I have the ST-RR-Evo on order and would like to know what lipo RX pack you guys are running. I would like to get the IP 2300 lipo...but will wait to see what fits. I have run HB for years and decided to try a higher end kit.
#1599
Yes, it popped off and I replaced the plastic end and it still has play on the ball end of the brace.
#1600
you can run the protek 2300 lipo as got mine yesterday and they fit like a glove
#1601
did it pop off?? if not, dont change it, i run my truck really hard and our track has huge jumps with few concrete landings it never moved from its place and still going strong. if it starts to move a bit, just change the plastic ends.
cheers
Ali
cheers
Ali
#1602
cheers
Ali
cheers
Ali
Ali, how do you like the MP9 radio box in your ST-RR??? Also how is the fit/finish of the box to the chassis and servo tray?
I was thinking of trying that too.
Thanks!
#1603
any one else ordered part IFW402B wing stay posts thinking they were for the new evo truggy(amain had them under strr-evo parts) dont bother as they are just the same as the part IFW402 BUT ABOUT $6USD DEARER and now amain have them as MP9 wing posts..so there is 2x part numbers now that are the same thing..crazy.
#1605
Motor mount, brakes, and the front rr shocks are the same as the rear tki2 shocks
