Kyosho ST-RR
#3091
#3093
ok. thanks fellas.
#3095
I am still running a ST-RR but as I needed to replace any of the above mentioned parts I purchased the EVO version and there is no difference in handling that I can tell.
I recently replaced the chassis with the M2C chassis and at the same time I put the M2C forward battery mount modification too. I did notice that I had more steering that in the past and I don't know if it was the chassis or the moving of the battery forward or some combination of the 2 that made the difference.
Lee
#3097
I have all the parts you need to complete this in stock. Call me if you need more info.
Lee
770-972-0636
#3098
Anyone using the Kyosho Brushless conversion on an ST-RR EVO? What do you think of it?
http://www.amainhobbies.com/product_...Conversion-Kit
#3099
#3101
also have the m2c front and rear hinge block systems and the radio tray which is very neat and tidy. nice parts from m2c!
however slightly annoyed that you can only use the m2c front bumper with the front hinge block.
on another note, replacing the drive pins in the universals? is it possible or do i need new universals?
i faintly recall reading that they are not replaceable on the kyo universals..
#3103
Any word on the m2c chassis yet?
#3104
i also have the m2c engine mount, it is a lot better than the kyosho mount, used it for a 3 day state title event and it didn't budge at all.
Lee
#3105
Thanks, yep I have 2 off those coming, m2c also said you can fit the kyo one but it clearly needs a fair bit of dremelling, which I am very bad at.
