Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder B
King Headz KP-300UL-BLK Front Upper Holder L
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 06-17-2020, 05:01 PM
  #4591
CarlCrocco's Avatar
Trader Rating: 92 (100%+)
Originally Posted by CrAzYoNi
Sorry for popping-up this great thread!
I've got a kit of the STRR Evo 2. with an electric conversion I'm finishing those days, got the whole kit and parts getting dust for over 3years now due to some medical issue...
Anyways, I've installed the motor house with the stock Spur 50T and wanted to use the 4x15mm screws - but it seems:
A. The motor house is not stable as with the 4x12 screws - I can shake it by my hand without making too much of effort
B. The screws don't get the whole way inside (they are a bit bold-out from the bottom of the chassis)
Any idea what am I missing anything?
I'm building it based on Kyosho electric conversion & HobbyWing XR8 Plus (150A) + Xerun Kv G2
Thanks in advance!
That mount sucks, You can make it work but I recommend the one M2C Racing.
https://www.amainhobbies.com/m2c-kyo...2c2825/p742400
If your going to use the 50t spur you'll need some spacers.
https://www.amainhobbies.com/m2c-1mm...2c9610/p267815
Or you could go composite with no spacers
https://www.amainhobbies.com/kyosho-...462801?v=17048
CarlCrocco is offline
Old 08-06-2020, 01:25 PM
  #4592
Originally Posted by houston
Anybody interested in a nib strr evo.2?
Do you still have the Kit?
Kyosho_2011 is offline
Old 02-13-2021, 02:11 AM
  #4593
i have the rear block system from m2c. I want to set 3 degrees. I take the inserts with 2 points right? For the rear block I put the inserts so that the points point inwards and the recording is moved outwards. right? for the front block how around should I put the inserts? Again the one with 2 points and how about? this moves the recording up or down. sorry for my bad english and thanks in advance
ChrisKrueger is offline
Old 03-02-2023, 10:19 AM
  #4594
sn47som1's Avatar
Does the Neo 3.0 St printed body fit the Strr kits? I don't feel like potentially having to trim 20% of the body off to get it to fit well. Is it an issue?
sn47som1 is offline
Old 03-14-2023, 03:54 PM
  #4595
Brian C.'s Avatar
No it will not. Its technically the same exact body, but the Neo ST is shorter so they trim the body in the back which makes it too short for the STRR i believe. The unpainted one will definitely work.
Brian C. is offline
