Mugen MBX5R
#316
I was wondering if any of these tires are any good? And witch compound is the softest? (WD, BKD,WS)
Has any one tried them?
And they are only $23 shipped for 4 mounted tires! :shock:
These look like CF knockoffs. [-X
http://cgi.ebay.com/NIB-Racingspike-...QQcmdZViewItem
These look really cool also. 8)
http://cgi.ebay.com/NIB-Mohawk-BKS-P...QQcmdZViewItem
http://cgi.ebay.com/NIB-PRO-Mohawk-W...QQcmdZViewItem
http://cgi.ebay.com/NIB-Mohawk-WD-Pr...QQcmdZViewItem
#317
hi guys!i have a mbx5prospec and i am thinking for 2 engines.the os vzb v-spec and the axe rossi cobra.which is the best?the most reliable?with the cheapest parts?and pipe? from the jammin pipes {jp1,jp2,jp3}?
#318
I went with OS for my engines in 1/8th. I got the vspec for my 5R and the XZ .28 for the 5T Prospec. I used to run nova based engines, and I wanted to try out OS big blocks. I love the CV-R I run in gas truck, so why not try em. I got the JP-3 for the v-spec as thats what most reccomend on the grid. Ill be breaking the vspec in this weekend, and hopefully will have the 5T built to break in the XZ! Cant wait!
#319
What compound of Crime Fighters come in the MBX5R kit? Thanks
#321
Brakes
New to this forum.Rc big in South Africa.I use this brake system and it works great very smooth never fades Werks links and t/t disks all from A-mains.
#323
It doesnt bind at all.The ball link wire slides through the plastic section on the servo horn.I use springs instead of fuel tubing, the brakes are much smooooother this way.I also have very little play between the calipers.The use of cap screws without the threaded section on the calipers is even better.With this system its less clutter and the fuel pipes are safe!Its really worth the effort.
#324
#325
Yes it does rub against the body but very little.Ijust stuck a small piece of 3M bike face on the body,but its not really a problem.Nothing more than standard setup.
#326
#327
Great I like very a fast throttle used to run airtronics 94758 0.6s @6v This servo is as fast although it has the same spec as a 9451. The standard servos dont last,their motors is the problem.Futaba says BLS451 last 5x longer.I also run lipo's with my own regulator 2x 10A diodes in series with the batt. cheap and works better than any of the "high tech" stuff!!!
#328
any news on the mbx6?
#329
there is going to be a 6?
I just got the 5r.
I just got the 5r.
