Losi 8ight building and setup
#6781
Has anyone seen the LOSA3553 and LOSA3554, I wonder if the they are bit longer than the standard ones.
Does anyone know?
Does anyone know?
#6782
Qconcepts losi 8ight split diff mount
Anyone know who has a Qconcepts losi 8ight split diff mount in stock?
Jim
Jim
#6783
#6786
Qoncepts themselve's prolly does...but they arent exactly cheep....I am too in the market for another 1 for my buggy.....Lost a damn auction on ebay for a B.N in package mount...Grr
Yeah I can't get a responce from Qoncepts. Found a LHS but they are out of stock. If I find one I'll let you know.
Jim
#6787
#6791
buggy front clutch bearings ?
Hi All,
My losi is destroying the front bearings every 20 mins or so, I have replaced them so often I lost count.
I run standard 4 shoe losi clutch and shim / adjust the clutchbell for endfloat.
Has anyone got any ideas??
Cente diff moving? or anything else common.
Many thanks .
Many thanks .
#6794
Actually the pin is through the cup's shaft on the inside of the diff. It acts to key the beveled gear in place and to hold the shaft in. Take the gear off by pulling it straight up being careful not to mess with the teeth. You will then be able to slide the pin out of the shaft for removal.
Pay attention to your bearing orrientation and grease the shaft when you reassemble it.
Hope this helps.
Tex
Hope this helps.
Tex
