Losi 8ight building and setup
#6226
In sanctioned races here in the US, I have not had a problem with fuel specs while running without the provided tank insert. I do not run any external filters and I do run the line directly to the engine with very little excess.
Now on the truggy it is illegal to run without the insert.
I do not know the measurements but that is what I have seen.
TEX
TEX
#6227
Any one running the new chassis?
#6228
never had a prob with mine at scrutineering, i had plastic insert in tank and measured 116ml with the fuel line. they only count the fuel line from tank pick up to the carb, the return line doesnt matter(can be as long as you like). just thought id let you know incase your measuring both lines
#6229
I ran it with my car last weekend at 2 different tracks. A definate improvement. More forgiving to drive in the rough and I think it turns better. From what I understand that it will not hurt to run the chassis in any situation or track condition.
#6230
Has anyone had any trouble with the throttle servo getting overheated or worn due to the engine heat? I am looking for some type of kevelar shield or tape to help keep the heat off of my JR 9000 servo. I have just started into my race roller T and RTR 8.
#6231
huh ? throttle burnin up cuz of heat...i dont think so...worn due to engin wear ? How hot are u running ur mills 300+ ?
#6233
#6234
7Amh battery, and it lasts forever on one charge.
If your looking for an alternitive to the Losi box, this is an option.
I dont know too much about the Losi boxes, but i can tell ya I have seen MANY times, at the track, guys runnig around asking to use someones elses Losi box. i just dont have time for that.
#6235
All u need to do is rewire the box with Deans Wet Noodle and Solder all the connection's and should be an Obvious but 99% of guys dont do it...but u gotta break the box's motor's in....U cant just go rammin on them right outta the box and expect them to last that long....Like any electric motor...the brushes need a little time to break in and get well suited to the comm.....Ive ran my box for a total of like 5 race weekends and have yett to have any issues....keep in mind i got mine like 3 month's ago....AFTER i talked to losi and they claimed the 1st Batch of motor's were bad(new supplier) and they assured me the newer boxes out were fine and should'nt have any issues....i rewired mine for peace of mind...and i also use a Gel cell...stick packs arent well suited for box's imo...for the price u gotta pay for decent cells...u could have bought 3-4 gel cells no problem. this is basically how i did mine minus the lipo's.
#6236
Integra, you could try the losi heat tape. I don't feel it is a problem, but this stuff should help. http://www.losi.com/Search/Default.a...archTerm=nomex
#6237
That box won't be lacking any power.....
#6238
huh ?
#6239
#6240
I was wondering how many of you guys that own a 8ight B race roller have had any out of the box assembly issues? All of my 8ight T race rollers have had top notch assembly but when I took my new buggy out of the box I immediately saw one of the front chassis brace screws hanging way out from under the chassis. I went over the whole bottom of the chassis and all the rest of the screws were tight. Then today when I was running the first tank through it the brake linkage vibrated off. I guess while they were busy putting too much red loctite on the wheel hubs they forgot to loctite the tiny setscrews in the brake collars.......
